Touring Frame Upgrade
I had an 07, now have an 09. MUCH improved. BTW, the stock suspension on the SG is much better on the 09 than on the 07. Its still a compromise compared to the Ultra, but its MUCH better than prior years IMHO. It was a bit stiff at first, but after a few thousand miles, Im happy to leave the 12" shocks on my 09. I replaced them with 13"/lowering blocks on my 07. The increase in load rating is VERY noticable to me. My 07 always felt like the suspension was overwhelmed if I had my wife on the back, even at full air pressure. (She's only about 135 pounds, not a large woman). Much better on the 09. You still need to be more accurate with how much air you have in for a given load, compared to having full length shocks, but its MUCH better than my 07.
Its nice to have some MEAT on the back end as well. (the bigger rear tire) Hell, even the OEM tires are TON better than the older ones. First time Im happy with the stock tires, and not looking to upgrade to another brand.
The ONLY time I would not recomend an 09-10 is for someone who has short legs. As the frame is a bit wider in the midsection, it is a bit longer of a reach to the ground. Not a problem for most, but a few shorter riders have found it to be just enough to cause them issues getting their feet down.
BTW, I DID have a true-track on my 07. Still not as tight as my 09.
Also, the slight change in gearing and the addition of the IDS in the rear hub, makes a good improvement in acceleration and overall smoothness compared to the 07.
One other thing they changed, was the front end geometry. (slightly) Something I've noticed, Is I don't get the front end batwing waggle when around Semi truck turbulence like I did on my 3 other pre-09 bikes.
I ride moderately aggressive and like my 08 flht over his bike. Now, I've never ridden an 09 or later EG(fill in the blank) so I can't compare that.
I 100% do not regret buying the 08 over the 09....I had a choice and am glad with my choice.
More than once I have been in a good curve and realized that I was going at least 10 mph faster then I used to take the same curve before on my 01 FLHTCU.
Mr_Bill
The 09 and 10 bikes are nice but if it helps any in your decision process we are still installing our units on the new bikes as well due to the rearsteer issues.
True-Track
