Best 2 into 1 Exhause
Old Apr 4, 2010 | 01:49 PM
mike5511's Avatar
mike5511
Default Best 2 into 1 Exhause
Is there a "best" 2 into 1 exhaust system, or are they all pretty much the same? I am more interested in "rideability" and performance than in sound. (In fact I'm looking to quiet things down without losing performance. Also more interested in low end torque than top speed and high HP numbers.) I am looking to gather information in support of a possible future purchase. I've read the manufactures claims, (I have also used the 'search' function thank you very much! ) but I'd like to hear what those of you who have the "2 into 1", as well as what you Tuners out there have to say.
Thanks, Mike
2008 Ultra Classic
Dresser Duals, SERT, SE a/c
(SE 255 cams likely addition in the future)
Old Apr 4, 2010 | 01:52 PM
bunkerbeer's Avatar
bunkerbeer
If you are looking for more low end then HP, 2 in to 1 might not be the best option...
Old Apr 4, 2010 | 03:26 PM
qtrracer's Avatar
qtrracer
Most of the 2-1 exhaust systems are very close in performance and the 2-1 is the best choice for performance ,torque and hp, when was the last time you saw any non super charged engine without a 2-1, 3-1, 4-1,5-1 header type system, yes they all have them cause they work the best in 99% of all applications , I say 99% percent cause I can't think of 1 instance now where a non-header type self scavenging system will work better but I could be wrong. Drag racing , circle track, nascar,indy, formula 1, every non-supercharged engine, that is looking to be the best runs this type, take advantage of their R&D.
Old Apr 4, 2010 | 03:59 PM
arealinvestor's Avatar
arealinvestor
Thanks, Mike
2008 Ultra Classic
The best all around 2 into 1 for the street is D&D's Fatcat,Fatcat Boss & the Boarzilla.JMHOP!!! All 3 exhaust when paired with the right parts make great HP & TQ.The fit & finish is also very good!!! JMHOP
Old Apr 4, 2010 | 04:32 PM
07RoadHawg's Avatar
07RoadHawg
Gotta agree on the Fat Cat. I have the quiet baffle version and the motor has a nice long flat torque curve. Torque jumps up almost to max at 2500 and stays there until 5000. Fit and finish is top notch, and Dawg recently had a really good customer service experience with them.
Old Apr 4, 2010 | 04:36 PM
harleyflyboy's Avatar
harleyflyboy
I had these www.rbracing-rsr.com/ on my '05 Ultra, really did like them. They were a little too loud for my wife so didn't put them on the '09. The web site is an interesting read.
Old Apr 4, 2010 | 04:39 PM
FUZZY's Avatar
FUZZY
D & D all the way!
Old Apr 4, 2010 | 04:48 PM
'05Train's Avatar
'05Train
The Fatcat all the way. Be prepared for a little extra heat on the right side, but the power and the sound can't be beat.
Old Apr 4, 2010 | 04:52 PM
kiwifulla's Avatar
kiwifulla
rb lsr give great power and thunder header are also great
Old Apr 4, 2010 | 05:08 PM
hog-doc's Avatar
hog-doc
Best performing (on the dyno) 2-1:
1: Road Rage
2: Fat Cat/Boss
3: Pro Pie HO
4: ThunderHeader
5: Rb LSR
Best fit/finish, looking:
1: Fat Cat/Boss
2: everything else
Best sound:
1: Boss w/performance baffle
2: Road Rage
3: ThunderHeader
Lowest performance (again on the dyno) these pipes just dont make the numbers they should:
Rinehart
Big Radius
Caliber
Pro Pipe
