SE pushrods, which set?
Old Apr 4, 2010 | 03:40 PM
IndyClassic's Avatar
IndyClassic
Default SE pushrods, which set?
Putting together list of items needed to do the 96 TC cam swap. I am doing the bolt-cutter method and installing adjustable pushrods. I see two sets listed for the 08 96TC. 18404-08 and 17997-99A, what is the difference?
I think the only thing that scares me about the swap having read iclick's and atrain68's great write-ups is going to be adjusting the pushrods properly. The 17997-99A does state they are for cam changes where heads are not removed so I am pretty certain they are the ones I need.
Or are there other brands even better?
Old Apr 4, 2010 | 03:48 PM
dawg's Avatar
dawg
The -08 are tapered and can/should be used with higher lift cams. The -08 ones are also better because it does away with the pushrod rubbing on the tube top like the -99A's are prone to do. Either set can be used without removing the rocker boxes.
UltraKla$$ic's Avatar
UltraKla$$ic
Both will work, I liked the Premium tapered 18404-08 a bit better than the older ones as they seemed to be a bit better tensil strength and the tapered end was nice too.
6 one way, half a dozen the other. Either one.
Old Apr 4, 2010 | 03:54 PM
IndyClassic
Thanks!
Old Apr 4, 2010 | 06:51 PM
slick813's Avatar
slick813
Put this in the for what its worth file. I followed Iclick and Atrains threads that were excellent, I installed the 255s with the SE tapered adjustables.
Followed the instructions and everything went as planned until I started it up and the valve noise was terrible, like a pushrod wasn't adjusted right. I had put the front cylinder at TDC, then I adjusted the pushrods till they were snug, then tightened them 2.5 turns, my lifters took about 30 minutes to bleed down and then I could turn them like the instructions said. Then I did the rear cylinder the same way.
It sounded like **** and by then I was pretty bummed, then I started reading the threads about adjustables coming loose and I said screw it and took it to the dealer and told them to put solid pushrods back in it. they charged me 3 hrs @ 65 labor and $ 100 something for the SE perfect fit pushrods, so I am pretty happy now.
I am sure I must have done something wrong, maybe they were not truely on TDC, I am not sure. Good luck.
Old Apr 4, 2010 | 07:32 PM
IndyClassic
Missing TDC was most likely the cause, adjusting those in is the part that scares me the most.
iclick as I recall actually pulled the heads using the wood block trick and since I only have the cams on the workbench at the moment that is still an option not completely off the table.
Now if I could just get one of the guys over at that point of the reinstall for beers and steak to set them right.....no worries!
canuuk01
Dec 11, 2014 01:59 PM
Juice
Engine Mechanical Topics
Oct 21, 2014 09:36 AM
myanoch
Dec 30, 2013 05:35 AM
dennyo
Mar 2, 2013 08:39 PM
loc
Exhaust System Topics
Dec 12, 2008 10:29 PM
