Flag Pole
Old Apr 9, 2010 | 01:59 PM
jbud47's Avatar
jbud47
Stage IV
Default Flag Pole
Hey guys,
If anyone is flying a full size flag in PGR or WWR rides, what material is your flag pole made of?
Thanks, Bud
Old Apr 9, 2010 | 02:42 PM
Buddha64's Avatar
Buddha64
I use a Chrome six foot closet pole. I put two eyelets in to attach the flags to, a layer of electrical tape to keep it from rattleing too much. I also cross drilled the pole with the holder and have a quick release pin through it for peace of mind. Had it up to 70 MPH with no problems.
George.
Old Apr 9, 2010 | 05:49 PM
HogAir's Avatar
HogAir
Here's a reference for you on flags and mounts.
http://*******.com/y2dqpf5
I'm running two 3 x 5 flags on a Rivco mount on my Ultra. I substituted 4 to 8 foot poles unlike the 6 to 12 footers described in the writeup. I've been using them for 2 years and way too many missions. Best mount's you can put on a bagger I think.
Alan
Old Apr 9, 2010 | 06:55 PM
Lenyaw's Avatar
Lenyaw
I also use the Rivco mount on my Ultra, but used two 6 foot wooden closet rod for flag poles. They required a little sanding on the belt sander to make them a tight fit. I added 2 more grommets to my 3 x 5 flags (4 total) for more strength at higher speeds. I used 5/16" eye bolts drilled through the poles and attach the flags with 1/4" spring clips for easy removal after each mission. Flags have flown trouble free for over two years, other than normal wear & tear. They have held up to speeds...well...in excess of parade speeds ** (& I'll leave it at that)...(**NOT recommended, the bike does get a bit sensitive at those speeds)
Old Apr 10, 2010 | 04:45 PM
Johan96's Avatar
Johan96
putting on notification
Old Apr 10, 2010 | 05:05 PM
michael427's Avatar
michael427
A 4 or 5 ft. nightstick cb antenna works fantastic even at highway speeds. Everyone in my capter uses them now.
Old Apr 11, 2010 | 06:23 AM
jbud47's Avatar
jbud47
Stage IV
Default Flag Pole
Thanks for all the info guys. I appreciate all the help. Bud
Old Apr 11, 2010 | 06:49 AM
littlebear's Avatar
littlebear
Made my own mount that bolts to the luggage rack, for the pole I used a paint pole I got from Sherwin Williams paint store, painted it black and it is plenty stout. Alot of guys have found old mic poles that work well, hit local pawn shops for that find, good luck.
TooEasy
The Patriot Guard Riders
164
Dec 21, 2022 01:15 AM
slodsm
Audio Systems
Feb 27, 2019 08:51 PM
jpalm
Dec 7, 2010 09:32 AM
