Issue with pc V
Old Apr 9, 2010 | 09:14 PM
thumper05's Avatar
thumper05
Default Issue with pc V
loaded 2 maps, set up the switch good but maps wont switch ??
have the laptop hooked up and it shows map 2 and wont switch between maps...
Any ideas?
Old Apr 9, 2010 | 09:21 PM
09StreetGlider's Avatar
09StreetGlider
Never tried 2 maps because I run AT, but I'm interested. Subscribed
Old Apr 9, 2010 | 10:00 PM
iclick's Avatar
iclick
I don't know about the PCV, but the PCIII would not switch in the software until you closed and re-opened the app. IOW, to change maps you should first close the software, flip the switch, and then re-open the software. With the PCIII the maps will switch but the software only sees the map it saw when first launched.
Old Apr 9, 2010 | 10:09 PM
Sancho's Avatar
Sancho
Try starting your bike with your laptop hooked up to your PCV and see if it will switch with the bike running. On mine the bike has to be running.
Old Apr 9, 2010 | 10:32 PM
Beach Bagger's Avatar
Beach Bagger
Any ideas?
Had this set up before I got the TTS Mastertune. The bike does not have to be running to switch between maps, but you do have to cycle the run switch on and off in between fliping your map switch when the bike is off. Put your map switch in one position with your laptop connected and turn on the run switch. Now turn off the run switch and flip the map switch to the other position and turn the run switch back on. You should see your map change. This happens on the fly when the bike is running. If the map is not switching after doing what I described then check your wiring.
Old Apr 9, 2010 | 10:52 PM
SICKBAGGER's Avatar
SICKBAGGER
The bike has to be running with mine then when you switch it you can see on the right side of the software it will show which map you are running. You can enable map swithc in config and then load two maps and selcet which switch it goes to. But you have to have the bike running to actually switch and see the change.
Old Apr 9, 2010 | 11:10 PM
Sancho's Avatar
Sancho
Just start your bike up while your laptop is connected. It's not as confusing and will show other info as well and not hurt anything.
Old Apr 10, 2010 | 07:01 AM
papifun's Avatar
papifun
bike has to be running or the map # will not toggle if switched. but you should be able to download the 2 maps and see a split window on laptop so you are sure you have the two maps in the PCV. also - make sure you have selected MAP SWITCH to ON on the PC Configure tools.
All Aces
Jan 10, 2014 08:17 AM
NAUIdvr1
Fuel Moto / Jackpot Mufflers
Apr 26, 2010 03:07 PM
thumper05
Apr 10, 2010 03:22 PM
Sancho
Mar 26, 2010 09:06 PM
flight
Mar 22, 2010 08:29 PM
