how can i tell if my road king has a security system?
Old Apr 18, 2010 | 08:20 AM
ohiochris's Avatar
ohiochris
Default how can i tell if my road king has a security system?
I bought my 2004 road king classic a little over a year ago, the bike was a repo so the guy i bought it off of couldn't tell me anything about, it didn't come with a key fob, so i was just wondering if there was any way to tell if it did have a security system.
Thanks
Chris
Old Apr 18, 2010 | 08:24 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
If you don't have a key fob follow the instructions for setting the personal pin in the service manual and if it works you have one, if not you don't. Or you could check for the security system module. Check the manual for location.
Old Apr 18, 2010 | 08:30 AM
shortride's Avatar
shortride
I'm not sure about '04 models but when you turn the ignition off, the marker lights will flash. Indicating the security system is armed. There also is a red blinking security indicator on in the face of the speedometer on the Road King. If you haven't seen this, you most likely do not have an H-D security system.
Old Apr 18, 2010 | 08:40 AM
1flhtk4me's Avatar
1flhtk4me
If it's like my '06,It wont blink until you activate the fob.However,you may be able to see the outline on the gauge without the light blinking.
Old Apr 18, 2010 | 08:56 AM
AluminumGT40's Avatar
AluminumGT40
Default Harley Security ?
The best way is to find the TSM/TSSM HD module and see if it says; "FCc, tested to comply with FCC standards". If it has the FCc mark, it has the security system.... I too bought a 2003 FLSTCI not knowing the prior owner. My bike started and would drive great. I drove for a time while I too studied the HD security and options. I bought a new module and fobs. Then when I went to install I found that the bike had the HD TSSM security module. I reset the system and everything works great now I reset the FOBS, personel code and all by myself. Now I have a TSSM security module I don't need.
Old Jun 23, 2020 | 03:06 AM
Lawrence Henry's Avatar
Lawrence Henry
Stage I
If your interested in selling your extra tssm please let me know . I’m Larry @. 530-554-3189 or friscolarry707@gmail.com , thanks for your time
Old Jun 23, 2020 | 02:11 PM
Vernal's Avatar
Vernal
Hi Larry and welcome to the Forum.
If you look at the upper left of the post you replied to it shows the date of the post, 2010. You can click on the posters ID and see all their post and it looks like GT40 hasn't posted in 8 years.
Ebay may have some TSSM's but make sure you get the right part number. Here's a good site for looking up part numbers http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Old Jun 24, 2020 | 08:56 AM
btsom's Avatar
btsom
Larry, a suggestion. Use the search function and observe the very numerous problems with the security system. Most are caused by FAILURE to read the owner's manual and failing to replace fob batteries AND to set a pin. However, a perfectly healthy security system can be inoperative in an area of heavy radio frequency radiation. The serious thieves can take your bike even with a security system (a van and a lift) and the "joy riders" will be discouraged by a locked ignition and fork. As always, your money, your choice, just read about the added hassles for which you will be volunteering. I always get flamed a bit when saying this, so read those responses also.
phxlab
Sep 21, 2019 08:19 PM
DIESEL-FUMES
Jun 21, 2019 09:53 AM
Spur2018
Electrical/Lighting/Alarm
Mar 10, 2018 10:03 AM
cajun1957a
Mar 3, 2016 01:48 PM
1Reaper
Sep 7, 2008 11:03 AM
