Unexplained battery drain 2004 Road Glide
Old Apr 19, 2010 | 09:14 PM
mtnrydr's Avatar
mtnrydr
Stage I
Default Unexplained battery drain 2004 Road Glide
I have replaced the battery three times in 2 years. The battery is on a battery maintainer during winter months and stored in a heated garage. I have taken the bike to a bike mechanic three times for this issue and still nothing. I just brought it back to the shop last week. He spent 4 hours of trouble shooting and came up with the needing to replace the voltage regulator, which I did. This did not fix the problem.
In idle the battery light comes on intermittently.
Any ideas would be greatly appreciated.
Thanks.
Old Apr 19, 2010 | 09:33 PM
JDB's Avatar
JDB
Default Battery
I will assume that the battery is charging at around 13 to 14 something when the bike is running.
Is the bike draining the battery when it is sitting. If this is the case you may want to shut off the bike and place an amp meter between the positive post and the positive battery terminal and see how much current is being drawn by the bike when it is turned off.
If it seems high start pulling fuses until the current draw is eliminated and see where the current is going.
Not much else I can come up with from your discription of the problem, except buy a different brand of battery.
I would assume that all possible chassis grounds have been checked.
Old Sep 30, 2011 | 08:59 AM
donaldhewitt66's Avatar
donaldhewitt66
Stage I
Default Battery Drain 04 Road glide
I have the exact same problem on my 04 RoadGlide. Pulled all fuses. Only the main stops the drain. It is a full power drain.
Did you ever find the root cause of the problem? I knwo that HD is going to recommend the Regulator as well but I doubt that is the issue, I replaced that a few years ago. I suspect it is the computer.
Old Sep 30, 2011 | 10:57 AM
mkguitar's Avatar
mkguitar
there will be a slight drain due to radio and security system.
often batteries discharge through the dirt on the battery, keep it clean.
other than that methodically going through the electrical system at he fuse /breakers will show if there is a parasitic draw.
battery light at idle may not be related, but a charging system check is indicated esp. if this just started with new regulator.
and it is possible that your trickle charger is junk.
mike
Roni
Aug 5, 2024 05:13 AM
JOW_103
Dec 29, 2014 03:49 PM
RodeoHard
Electrical/Lighting/Alarm
Jul 24, 2013 11:21 AM
WOLFE1584
Mar 12, 2013 01:13 PM
sonar_chris
Jan 10, 2009 10:42 AM
