Fairing change on a '89 Electra Glide
Old Apr 26, 2010 | 05:43 AM
Big Gee's Avatar
Big Gee
Default Fairing change on a '89 Electra Glide
Hi all,
Does anyone know is it possible to change the front fairing on a 1989 Electra Glide Classic to a later model one ('96 later)? And if so, is it a big job to change the clocks etc? Thanks in advance. Gee.
Old Apr 26, 2010 | 05:20 PM
Ultra89Rider's Avatar
Ultra89Rider
I did change the Inner and Outer Fairing on my 1989 Ultra to the 1996 type fairing.
The fairings will bolt up to the triple tree without any changes but...
The major changes the Gages and in the top of the triple tree. The gages will need to be changes to match the inner fairing.
If you don't change the triple tree, the ignition switch will not work. The switch need to be the newer one to match the inner fairing. When you change the assembly, you will loose the front fork lock. I made a plate and welded it to the top of the frame a the fork pivot. This was so I could use the fork lock on the new switch.
You can use the original wiring, but I changed to the later model wiring so I could use all of the late model instruments.
bigirn
Aug 21, 2013 08:48 PM
NC_Grover
EVO
May 3, 2013 01:59 AM
sgtrod91
Feb 1, 2012 08:36 PM
JHC210
Jan 7, 2012 10:45 AM
Robsteeler66
Jul 9, 2011 03:47 PM
