SCREAMIN’ EAGLE® HIGH PERFORMANCE AIR CLEANER KIT FOR TC88
Air Cleaner Element Maintenance for the HD Filter
1. Remove the air cleaner cover and inspect the element
every 5000 miles (8000 km), or more often under dusty
conditions.
2. To clean the element, remove and wash by Immersing
it, on edge, in a shallow pan containing enough Air
Cleaner/ Degreaser, Part No. 99883-88T to cover no
more than 3/4 the depth of the filter pleats. Do not let
dirty solution get inside the element. Carefully “roll”
the element in the solution around its perimeter until the
entire outer surface of the filter pleats has been soaked.
3. Remove the element from the cleaner/ degreaser and
allow five minutes for the cleaner to dissolve the dirt.
From the inside out, rinse the element with cold water.
Shake off excess water, and allow the element to air dry.
Do not dry with compressed air.
NOTE
This is a DRY air filter. DO NOT apply oil to the filter element.
NOTE
When servicing the air cleaner, apply Loctite® 243 (blue) to
all fasteners (both male and female threads). Loctite 243 is
available as H-D Part Number 99642-97.
Took my POS SE ACto the stealer and was told by the owner that it is a POS and that he wouldn't put it in any of his bikes. He buys and runs K&N in everything he personally owns. Offered to sell me one (K&N part # HD 800) but I chose to order it on line.
