Overcharging?
Old May 5, 2010 | 09:05 AM
ffd796's Avatar
ffd796
Thanks, I will post the code in a few if I can get it!
Old May 5, 2010 | 09:20 AM
ffd796's Avatar
ffd796
Well you guys rock, and to think that I was going to go purchase a code reader for $150.00
OK, here is what I got:
P1357
when I cleared the code this scrolled on the display
PN 32915-07
Not sure what that was but my code is now gone and the light is not showing a historic code.
now the question is what in the hell is P1357
Old May 5, 2010 | 09:23 AM
ffd796's Avatar
ffd796
P1357 Intermittent Secondary Front EFI
Hmmmmm that does not sound good.
Old May 5, 2010 | 12:34 PM
chasswartz's Avatar
chasswartz
My manual says to check spark plug cable resitance, and plugs must be correct HD type for this model. You should be able to swap front and rear cables and plugs. Code P1358 would be the code for rear cylinder. If the code switches to the rear cylinder, you have a plug or cable issue.
Codes P1357, P1358, P1353, and P1356 are caused by a missfire or lack of continuity in the ignition coil secondary circuit.
Old May 19, 2010 | 03:09 PM
mtnmod's Avatar
mtnmod
Default Overcharging
My 10 SG also reads 15 volts so I checked the charging and found 14.3 to 14.5.I'm thinking some gauges are out of calibration.
Old Apr 7, 2011 | 03:08 PM
HB's Avatar
HB
I know this is an old post and might have already been mentioned but mine done the same thing and they told me to get plugs that the top does not screw off. Fixed the same history codeon my 03
T Man
Jun 5, 2017 07:12 AM
rodney123456
Jan 5, 2014 09:33 AM
jlasoftail
Aug 20, 2011 06:18 PM
Xkikbxr
Jul 13, 2008 10:37 PM
trmn8r
Jun 16, 2006 01:14 AM
