HELP. Need wire color code for HK radio amp install.
Old May 5, 2010 | 05:47 PM
banks727's Avatar
banks727
Default HELP. Need wire color code for HK radio amp install.
I'm right in the middle of my Elf amp install and I can't seem to find the color codes for the Left and Right speaker wires (+/-)coming out of the Harmon Kardon stock radio head. I was told to look them up on the internet but can't seem to find them.
Hope to finish tonight. Any help would be greatly appreciated!
Thanks
Banks
Old May 5, 2010 | 05:53 PM
JonnyD's Avatar
JonnyD
Shoot me a PM, I can look em up in my repair manual. I have an 08, but I'm sure they're the same.
Forget it, here you go:
Right= light green/black & grey/red
Left= light green/white & white/orange
Old May 5, 2010 | 06:05 PM
banks727's Avatar
banks727
The guy at the amp store said to make sure which wire was positive and which was negative. Got your color codes but not sure which would be positve and which negative.
Thanks
Old May 5, 2010 | 06:08 PM
JonnyD's Avatar
JonnyD
Right= Grey/Red is neg
Left= Light green/white is neg
Old May 5, 2010 | 06:12 PM
banks727's Avatar
banks727
Thanks JohnnD!!!!!!!!!!!!!!!!!!!!!!!!
Old May 5, 2010 | 06:17 PM
JonnyD's Avatar
JonnyD
I'm just one of many who can help you. This place is priceless for info! Let us know how the system rocks, when you're finished
Old May 5, 2010 | 09:15 PM
piasspj's Avatar
piasspj
Careful with the radio and amp. They are filled with smoke, if you let it out they won't work.
Old May 7, 2010 | 03:58 PM
banks727's Avatar
banks727
I've gone from great sounding J&M's to crappy sound. So far the amp sounds so bad. Not sure what to do. Looking at changing the grounds. I have both wires together (the pwr gnd and the small black from the speaker connections. Could this be causing the problem?
The only other thing I can think of is if I have the +/-'s wrong. Don't know if this matters.
I also splice into the harness and connected the wires coming out of the radio to the amp. Maybe I should have grabbed them right off the speaker connections? It looks like that's the way the J&M amp guys did it.
I'm open to any suggestions someone might have
Thanks
Banks
UltraNutZ
Audio Systems
29
May 15, 2016 09:33 AM
BlackPearl#1
Audio Systems
Nov 22, 2015 11:27 AM
ShoreRider
Audio Systems
Jul 11, 2015 03:55 PM
Goodboo
Aug 30, 2012 08:02 PM
myred55
Feb 6, 2009 09:07 AM
