Transmission Dipstick?
Old May 28, 2010 | 12:15 AM
hog-doc's Avatar
hog-doc
Originally Posted by oryxs
Checking my transmission oil today ( 2009 UC ) and noticed that the dipstick has some chafe marks. Took some photos of dipstick and the cause. As you can see there's a piece of casting/milling left at the bottom. This chafes against the dipstick, which will eventually cause failure. Have started the warranty process with my dealer and will keep you posted.
Those arent chafe marks, that is where it was wired up during the chroming process, EVERY HD stick has those same marks in the same place!
If that spot in the bottom of the hole was touching the stick when it is installed there would be a decending spiral mark on the stick (from being screwed in) not an unchromed spot in 2 places!
Old May 28, 2010 | 12:16 AM
rkingw's Avatar
rkingw
Originally Posted by iclick
You're too cynical and don't recognize this as the marketing masterstroke that it is. HD Marketing Rule #1: Sell them two of everything possible. They can now sell all HD owners a second dipstick at $15 each, so think about the increased earnings potential here. It's a brilliant concept that follows so many other similar ideas like the SE compensator, big-bore kit, chrome fork legs, oil-temperature gauge, etc. Selling you two of everything is much better than one, for them. They start by making something weak (e.g., stock compensator), ugly (fork legs), useless (air-temp gauge), or too small (engine bore), and then offer you the new-and-improved part after you buy the bike. You of course can't buy it the way you want from the factory, as that would mean you'd only buy one of everything. See Marketing Rule #1 above.
Back to the dipstick, my feeling is this: Why check the tranny fluid at all? If it doesn't leak and you drain out 1 qt. and put 1 qt. back in for every change it will always be at the right level. It doesn't evaporate and isn't consumed like engine oil past rings and valve guides, so why check it between changes? I'll be cutting mine off tomorrow and I won't be buying a new one.
I agree, no need to check if no sign of leak. My only concern would be if I did notice a leak and not being able to check the level to see if it's safe to continue riding.
Old May 28, 2010 | 07:00 AM
oryxs's Avatar
oryxs
Thanks for the info Hog-doc. My thought was more along the lines that the clearance between dipstick and the piece of metal is so little that the vibration of the motor causes contact. The mark at the bottom is actually more of a groove. The top one looks like the chrome just came off.That's why these forums are so helpful. I'm sure Harley technical will come back with the same info.
After your post I went to check again and do some measurements with the micrometer. If the piece was actually making contact with the dipstick it would be exactly half way between the two marks. DOH, Should've done that the first time around. Live and learn.
Old May 28, 2010 | 07:25 AM
BLKBAGGER's Avatar
BLKBAGGER
I always cut mine off when i get a bike. I never use it as I drain and fill with 22 oz and never check unless i have a problem. No problems yet.
Old May 28, 2010 | 07:37 AM
t059736's Avatar
t059736
Boy - some people are so smart~!
Just READ iclick's message and you'll see what I mean!
I am being serious here; he's right on the "money".
Ride In Peace
Old May 28, 2010 | 07:39 AM
don2010's Avatar
don2010
I have an 02 lowrider and 09 roadglide and have not had this problem on either one. no one I know has had this condition.... maybe this is isolated or owner caused problem...
mmcbryde
Sep 5, 2019 08:51 AM
BigGelvis
Apr 26, 2013 09:05 PM
Santo
Nov 24, 2010 06:43 PM
tallboy56
Jun 10, 2009 11:02 AM
rrsjs5
Sep 24, 2008 03:03 PM
