Transmission Dipstick?
Old May 8, 2010 | 07:35 PM
SC_Compact's Avatar
SC_Compact
Default Transmission Dipstick?
I was reading another HD site and there was talk that the transmission dipstick was getting cut, by the clutch cable sawing across it, and falling into the tranny. The suggestion was to buy a second dipstick and cut off the dipstick and only use the threaded portion to contain the trans oil to avoid this possible problem. Then when it's time to check the transmission use the extra dipstick to check the level.
Has anyone else heard of this or exoerienced a problem?
Old May 8, 2010 | 07:39 PM
hog-doc's Avatar
hog-doc
That only happens if you install the stick behind the cable. It wont saw it off it will break it off first time you pull the clutch.
What really happens is it breaks off from vibration. It gets chewed up by the gears and youd never know it happened, wont hear it wont see it if you pulled the tranny apart. Its a cheap casting that disentigrates pretty quick.
Baker has a billet stick that is not supposed to break! Spendy though.
Old May 8, 2010 | 07:45 PM
lionsm13's Avatar
lionsm13
I read that too, as well as the suggested extra dipstick and will probably follow through with the advice..
Old May 8, 2010 | 08:03 PM
1flhtk4me's Avatar
1flhtk4me
I remember readind about that.I forgot what years.
No problem with my '06.
Old May 27, 2010 | 08:18 AM
oryxs's Avatar
oryxs
Checking my transmission oil today ( 2009 UC ) and noticed that the dipstick has some chafe marks. Took some photos of dipstick and the cause. As you can see there's a piece of casting/milling left at the bottom. This chafes against the dipstick, which will eventually cause failure. Have started the warranty process with my dealer and will keep you posted.
Attached Thumbnails Transmission Dipstick?-dsc_0563.jpg   Transmission Dipstick?-dsc_0566.jpg
Old May 27, 2010 | 08:22 AM
lionsm13's Avatar
lionsm13
I just did what the other site said and cut off the original dip stick and now use the cap for a plug. Bought another one from HD and will keep it just for checking. Figured that would be the easier route...
Old May 27, 2010 | 08:24 AM
t059736's Avatar
t059736
You have got to be kidding me, right?
This is another known problem caused by cheap material and poor design; and the customer pays.
Boy, does this ever become tiring........
Ride In Peace
Old May 27, 2010 | 02:18 PM
tedcmiller (Cry Baby)'s Avatar
Although I have not had any dip stick problems ever with any of my H-Ds (currently have 2007 and 2008 big twins), the solution to cut off the stick on one used to close the hole while using another to measure fluid is probably OK. The recommended change interval on H-Ds with six-speed transmissions is every 20,000 miles. Unless you have a leak or are obsessive about transmision fluid, this is not very often.
Old May 27, 2010 | 02:30 PM
SciFiGuy's Avatar
SciFiGuy
Hmmm,
First I've heard of this. I changed out the original dip stick with one of the HD speed check dip sticks a few weeks ago and didn't see anything. Of course I really wasn't looking.
Guess when I get home I'll have to check the old one to see if there any marks like oryxs's shows.
Old May 28, 2010 | 12:04 AM
iclick's Avatar
iclick
You're too cynical and don't recognize this as the marketing masterstroke that it is. HD Marketing Rule #1: Sell them two of everything possible. They can now sell all HD owners a second dipstick at $15 each, so think about the increased earnings potential here. It's a brilliant concept that follows so many other similar ideas like the SE compensator, big-bore kit, chrome fork legs, oil-temperature gauge, etc. Selling you two of everything is much better than one, for them. They start by making something weak (e.g., stock compensator), ugly (fork legs), useless (air-temp gauge), or too small (engine bore), and then offer you the new-and-improved part after you buy the bike. You of course can't buy it the way you want from the factory, as that would mean you'd only buy one of everything. See Marketing Rule #1 above.
Back to the dipstick, my feeling is this: Why check the tranny fluid at all? If it doesn't leak and you drain out 1 qt. and put 1 qt. back in for every change it will always be at the right level. It doesn't evaporate and isn't consumed like engine oil past rings and valve guides, so why check it between changes? I'll be cutting mine off tomorrow and I won't be buying a new one.
