Handlebar Adjustment
Old May 18, 2010 | 07:14 AM
dawg's Avatar
dawg
Originally Posted by jackhis
Thanks much for the tips. I think I need a service manual to do this kind of works. This is my first HD, and it appears that I have to remove the fairing to be able to loose the handle bar clamps. I really don't want to mess up anything.
There are 4 bolts on the clamps. To do all 4 you would have to remove the outer fairing, radio, ignition, and the fairing switch cap. Some only loosen 2 of them and adjust then re-tighten the 2 bolts. Anyone doing a swap should go with the one piece clamp like on 08 and later
Old May 18, 2010 | 10:49 AM
jackhis's Avatar
jackhis
How easy to remove the fairing? Why didn't I see any screws, or something like that?
Old May 18, 2010 | 12:09 PM
dawg's Avatar
dawg
3 screws are on the front (hold the windshield on), 2 screws are located under speakers (1 each side), and 2 screws are located down under and behind the fairing skirte (1 each side). Go to the DIY section here or do a search that will lead you there for "batwing removal with pictures" and it will show you their respective locations.
Old May 18, 2010 | 01:20 PM
jackhis's Avatar
jackhis
Thanks MUCH!
I will do that.
martin10
2018+ Softail Models
38
Jan 26, 2020 01:54 PM
mkguitar
Jan 2, 2017 06:29 PM
bigboy92
Aug 15, 2012 01:47 PM
craig11dyna
Jun 15, 2012 02:47 PM
FLHX08
Aug 18, 2011 04:16 PM
