Gary Beatty inner bearing pulled and installer tool
Old May 18, 2010 | 12:05 PM
dawg's Avatar
dawg
Originally Posted by Certified Drunk
Anyone have a picture of what I might buy?
Attached
Attached Thumbnails Gary Beatty inner bearing pulled and installer tool-puller-installer.jpg   Gary Beatty inner bearing pulled and installer tool-puller-20in-20sleeve.jpg   Gary Beatty inner bearing pulled and installer tool-bearing-20in-20installer.jpg   Gary Beatty inner bearing pulled and installer tool-installer-20with-20bearing-20and-20threaded-20bolt.jpg   Gary Beatty inner bearing pulled and installer tool-installer-20with-20bearing.jpg
Old May 18, 2010 | 03:55 PM
iclick's Avatar
iclick
Originally Posted by dawg
Attached
Does yours have the long bolt or a rod that's threaded on one end? See my photo in an earlier post.
Old May 18, 2010 | 05:43 PM
dawg's Avatar
dawg
The one in my pic is the TC88 tool and it has the bolt. Is your pic of the 96 or the 88 tool? I don't know if Gary made them different or not or if some are mixed or matched.
Old May 19, 2010 | 07:29 AM
iclick's Avatar
iclick
Mine's the late-model tool. It seems like you'd need the smooth part of the rod (i.e. not a bolt head or threaded rod) on one end to shove through the puller section.
Old Jun 2, 2010 | 06:55 AM
BoomerBob's Avatar
BoomerBob
Are there any other tools needed to do a cam change on a TC96? Trying to gather everything I'll need to do this. Also; where's the best place to get the Torrington B-168 inner cam bearings? I see Georges Garage has them for $26 delivered.
Thanks
Old Jun 2, 2010 | 07:26 AM
1931jamesw's Avatar
1931jamesw
Thanks
I think that's the only special tool you have to have unless you want to get a pushrods remover/installer tool or cam lock tool. You so need a good torque wrench that reads inch pounds and Ft lbs. Also I think j got my bearings for much leas online from Chicago HD.
Old Jun 2, 2010 | 11:03 AM
iclick's Avatar
iclick
Thanks
That's a ridiculous price on those bearings! You can get them from HD for $15/pair MSRP (#24018-10), which is reasonable.
You will only need a bearing puller/installer, torque wrenches (in/lb and ft/lb), the usual tool list (Torx, Allen, sockets, etc.), bearings, and the usual sundry parts (gaskets, o-rings, etc.). If you're re-using the stock pushrods I would buy the Fuel Moto cam-install kit ($50) which includes the Torrington bearings. OTOH if you're using adjustables you should probably part-out the few gaskets and o-rings you'll need, as there isn't much needed. The pushrod kit should have the 12 tube o-rings included. You'll also need a bolt-cutter if you want to cut-out the stock pushrods to install adjustables.
Don't worry about the two special tools mentioned in the service manual. The sprocket-locking tool is unnecessary since to torque the two flange bolts you can simply have someone hold the rear brake while the bike is in gear. I can't figure out why you need the "alignment" tool to put the cams in the cam chest, although I suppose if you're not careful you could get the two cams out of alignment by jumping a cog while installing it, but if you're careful I can't see this happening.
Old Jun 2, 2010 | 03:12 PM
atrain68's Avatar
atrain68
You don't need to spend money on the cam alignment tool on the TC96. I used the cam plate do the exact same thing.
Old Jun 2, 2010 | 04:38 PM
1fathog's Avatar
1fathog
I just got my tool from Mr. Beatty, he sells the bearings also. Tool and bearings w/ shipping $ 109.00
Old Aug 31, 2010 | 02:27 PM
masterblaster's Avatar
masterblaster
tagged
