Fly By Wire Throttle Failures
Old Jul 25, 2014 | 06:24 AM
  #51
SOLOLUCKY's Avatar
SOLOLUCKY
RoadisBill,
I hope the new wirte fixes it for ya BUT I am convinced my failures, on my 08 EGlide was from the big computer wires pug directly under the seat...the seat applied pressure to the plug thus making it lose connection for a tiny second and that tripped a "failure" in the computer system, It gave an error code but I cannot recall what it was. Since the plug cannot be moved (battery is directly beneath it) I cut a relief in the seat pan (plastic) directly over the plug, then used the rectangular piece I cut out, turned it 90 degrees, and placed it up in the seat pan to act like a bridge so the foam of the seat would not bulge down and bear on the plug.
My bike only did it when riding 2up. I weigh about 215 and my GF is about 130 so not a lot of weight really...but enough to torque the plug and lose connection.
You can read on here how to get the error codes and what each error code means. ya might try that before dropping moneys that will not/ may not fix it.
Old Jul 26, 2014 | 08:02 AM
  #52
47Norton's Avatar
47Norton
I'm old school and don't think very highly of TBW. You don't have to build something just because you can. Scares the hell out of me. I'll take cables any day. I have even read of some aircraft crashes because of this system.
Old Jul 26, 2014 | 08:04 AM
  #53
skiddd's Avatar
skiddd
I agree, some things are better left simple. I would rather have a cable system on my 2009 Street Glide, I'd feel one less worry about failure...........
Old Jul 26, 2014 | 08:14 AM
  #54
logical's Avatar
logical
Exactly....nobody ever had a cable fail and older design aircraft never crashed.
Old Jul 26, 2014 | 08:47 AM
  #55
skiddd's Avatar
skiddd
Oh look, another internet wiseass with nothing better to do than throw out sarcastic comments hoping to get a laugh or start an argument................ be on your way skippy, your too stupid to be here.........
Old Jul 26, 2014 | 09:19 AM
  #56
qtrracer's Avatar
qtrracer
Really? Never been a mechanical failure to cause a plane crash? You clearly were drinking when you chose your screen name. Or I didn't hear the sarcasm in your post.
Old Jul 26, 2014 | 09:24 AM
  #57
floridapoolboy's Avatar
floridapoolboy
The first time my bike has a TBW failure I hope it's not on the interstate doing 90! If it happens and I survive, I'm trading the bike in on a Softail (still uses cables)!
Old Jul 26, 2014 | 09:34 AM
  #58
RoadKingCop's Avatar
RoadKingCop
This thread is over 4 years old. I'd say most of the kinks have been worked out by now. My 08 never had a single issue to this very day.
Ben
Old Jul 26, 2014 | 12:25 PM
  #59
camo1ton's Avatar
camo1ton
I'm new to it after 35+ years of Harleys. I hate the small bit of slop in my throttle that you use to be able to adjust out with cables. Just sayin'
Old Jul 26, 2014 | 12:27 PM
  #60
smitty901's Avatar
smitty901
TBW failures not very common except in cases where someone has messed with it that was untrained.
