2010 ABS front brake issue
Old May 25, 2010 | 08:26 AM
KCFLHRC's Avatar
KCFLHRC
Default 2010 ABS front brake issue
I have a 2010 EGC and was out on a short ride on Sunday, about an hour. Towards the end of the ride I noticed that the front brake lever would pull all the way to the grip when stopping. If I pumped the lever a few times it would be OK until the next stop and then it would do it again. The fluid level in the reservoir is fine. The bike has about 500 miles on it and is equipped with ABS. Any ideas? I have an appointment on 6/5 for them to replace the front fender and install Security, I guess I'll have them look at it then.
Old May 25, 2010 | 08:56 AM
rmc115's Avatar
rmc115
The brakes function normally when the ABS isn't active. Probably air or bad master cyl. Keep us posted on the results. Mike
Old May 25, 2010 | 09:01 AM
'05Train's Avatar
'05Train
Yup, sounds like an air issue if you have to pump them.
northeimcustom
Feb 28, 2014 09:42 PM
SquidHead
May 3, 2013 01:26 PM
Smada Guy
Wheels/Tires
Dec 26, 2010 07:30 AM
KCFLHRC
Jun 28, 2010 06:23 AM
DeputyMike
Jun 26, 2010 03:21 PM
