Total Control
Old May 27, 2010 | 06:12 AM
skyhawk85u's Avatar
skyhawk85u
It definitely depends on both the skill and the equipment. I'm not sure the actual weight of the bike is the important factor though. It's 250 lbs heavier than the V-Star 1100 I just moved up from and I was amazed to find out how much more maneuverable my EGC is at low speeds and how much sharper and slower I can make turns.
Old May 27, 2010 | 06:33 AM
shortride's Avatar
shortride
They slip the clutch and use the rear brake a lot.
Old May 27, 2010 | 06:40 AM
skyhawk85u's Avatar
skyhawk85u
That's my other concern about actually learning to perform this well - I don't want to have to replace my clutch and rear brake as frequently as they have to.
Old May 27, 2010 | 07:06 AM
dog155's Avatar
dog155
It is really not a big deal it does take natural ability,confidence,and the desire to do well.Oh, and a machine that can be thrown around in a given course.Some of those cone courses,the turns are too tight to throw earlier baggers around because of dragging metal.
Old May 27, 2010 | 07:15 AM
TheDon81's Avatar
TheDon81
These techniques can be used with any motorcycle regardless of weight and size. Your using the Gyroscopic effects of the motorcycle to maintain stability.
Wet clutches are designed to slip so you wont have to worry about replacing those all too often, but rear brakes sure.
Old May 29, 2010 | 07:12 AM
coliseum's Avatar
coliseum
ok... I just watched ride like a pro v!
Whats that leather stuff he wrapped his engine guards with?
Old May 29, 2010 | 07:32 AM
skyhawk85u's Avatar
skyhawk85u
Not sure what that was but a motorcycle cop buddy told me that you can often get some pieces of old unusable fire hose from your local firestation. Zip tying that on works well.
Old May 29, 2010 | 02:43 PM
agent58's Avatar
agent58
Go to Home Depot and get a couple of pieces of pipe insulation .It will fit around your guards as its got a slit cut into one side.Held on with elctrical tape or zip ties.Works well.
wharfrat
Product Reviews
Feb 8, 2010 02:58 PM
Harleypingman
Jul 21, 2009 12:47 PM
toketee
Apr 5, 2008 12:52 PM
motorman857
Harley Davidson Videos
Jan 13, 2008 12:33 PM
2008FLHP
Jan 1, 2008 08:40 AM
