throttle-by-wire limp mode
Old Jun 9, 2010 | 08:40 AM
c50plus's Avatar
c50plus
It happened to me, it is the corroded conector behind the air breather. Dealer put new pins on connector and it has been fixed. I am an electrical engineer and I understand the failure quite well. There are two sensors ( Hall effect sensors) in the new fly by wire throttle. The computer reads the sensors which both must indicate the same position for redundancy. The sensors connect to the computer via a wire that travels thru the connector I mentioned. When a corroded pin causes an intermittent disconnetion the computer see different position indications in the throttle and shuts down in limp mode. This is ususally an intermittent problem so this is why you are able to power down and up an go, but it will happen again unless fixed. It happens at around 20 to 25 K miles.
Old Jun 9, 2010 | 08:54 AM
t059736's Avatar
t059736
I believe there is a HUGH lawsuit against a HD dealership over this same issue.
Rider was given his bike back and was told that the dealer had fixed the problem only they hadn't.
If memory serves me correctly, I believe he was a M/C cop.
Anyway he was killed due to the fault not being fixed in the throttle set-up.
Beware....
Ride In Peace
Old Jun 9, 2010 | 09:07 AM
jpbo's Avatar
jpbo
That afraid me
i will check myself for this connector's pin if corroded
i will let you know, when that happened i was in loud traffic and believed me
it something i don't wish to anybody
Old Jun 9, 2010 | 02:59 PM
Bertk's Avatar
Bertk
I would definitely check for any stored trouble codes. Here's a thread with the info to do so.
Old Jun 9, 2010 | 04:35 PM
harley-jones's Avatar
harley-jones
Subscribing!
Old Jun 9, 2010 | 04:52 PM
White Rock's Avatar
White Rock
Stage I
Double check your battery...mine went to crap in bum...you know where.
Turned out the battery had fried internally....we could get the Bike started..fly by wire said no on going anywhere.
Old Jun 9, 2010 | 06:10 PM
Toe Knee's Avatar
Toe Knee
it happened to me the 1st week i had my bike. it ended up being the ECU connector not being tightly fastened under the seat. my bony *** caused the connector to come un-done. It was VERY common for the 08 touring years. whomever set up my bike didn't fasten things correctly.
Old Jun 9, 2010 | 06:40 PM
shortride's Avatar
shortride
I thought you were talking about ED there for a moment.
Old Jun 9, 2010 | 07:10 PM
V2Evo96's Avatar
V2Evo96
subscribed
Old Jun 9, 2010 | 07:22 PM
pounder35's Avatar
pounder35
Ditto on this I've had just about everything replaced including the wiring harness and guess what It still did it (go into limp mode)
The connector pin behind the AC is the colprit Simply spray that with some contact spray or anti corrosion and that is the trick man... Hasn't happened to me for a while now.
