throttle-by-wire limp mode
Old May 30, 2011 | 08:06 AM
  #31
badjustbad's Avatar
badjustbad
Originally Posted by drspencer
I'm confused, where was the broken wire inside the sheathing, inside the handlebars?
Thanks
The broken wire was in the sheathing just under the throttle body. The wires make a sharp bend, which appears to cause a weak point where the wires break - probably with the help of heat and vibration.
Old May 30, 2011 | 08:31 AM
  #32
1flhtk4me's Avatar
1flhtk4me
Are those the wires that are held on with a large plastic clip behind the air cleaner?
I guess I should check mine because when I added the SE A/C, the support bracket is removed and the wires/clip are just hanging there.
Old May 30, 2011 | 08:39 AM
  #33
drspencer's Avatar
drspencer
Funny you mention that. When I installed my SE A/C, I removed the metal bracket & plastic bracket and zip-tied the three wire bundles together.
Old May 30, 2011 | 08:43 AM
  #34
1flhtk4me's Avatar
1flhtk4me
I guess I should do this before something happens!
Old May 30, 2011 | 08:46 AM
  #35
drspencer's Avatar
drspencer
No, I'm wondering if my zip-tying the wires together caused the problem.
Old May 30, 2011 | 08:50 AM
  #36
$tonecold's Avatar
$tonecold
I know this won't repair a broken wire or keep one from breaking, but on another thread that was addressing this problem it was suggested that putting di-electric grease on the connections would help fight the corrosion. I have done this on the ECM and the connector to the throttle body. One question: Is this a problem that is only common to the '08's or is it happening on the later models also? I have an '09. I'm curious if the throttle grip sensor has been upgraded on the later models. As for as TBW goes, cars and trucks have used it for quite a while now w/o too many issues (Toyota maybe being one). Hopefully the MOCO will get it worked out as it seems this is the direction they are headed with all models.
Old May 30, 2011 | 08:52 AM
  #37
1flhtk4me's Avatar
1flhtk4me
Probly could if the tie was too tight or something.
Although I have had no problem,I know the wires must be bouncing around.
Old May 30, 2011 | 09:54 AM
  #38
badjustbad's Avatar
badjustbad
The wires on top of the throttle body (for the injectors) are attached to a bracket. The wires we're talking about aren't attached to any brackets. These wires loop under the throttle body and terminate at the large plastic clip behind the left side of the air cleaner.
H-D may have changed the wires to something more pliable or less brittle on newer bikes, but they didn't change the routing or supporting of the wires. My '11 Ultra has the same setup with the tight bend in the wire. I carry crimp wire connectors in my tool kit, just in case it bites me again.
Old May 30, 2011 | 10:22 PM
  #39
Potato_Potato's Avatar
Potato_Potato
The problem could relate to this SB.
TT418: DTCs P2135 and P2101 Theory and Diagnostics
Old May 30, 2011 | 11:56 PM
  #40
drspencer's Avatar
drspencer
O.K., today I took off the fuel tank and air cleaner to get a better view of what's happening.
I clearly see the sheathed sets of wires under the tank, as well as the single sheathed set of wires that terminate with a connector to the left side of the A/C.
I pulled back the sheaths on all these wire sets about half an inch, and did not see anything obvious that look broken or split. There also weren't any funky bends or kinks that I could see.
I took the connector off the left side of the A/C, had a peek at the pins and terminal, and reattached it. Nothing obvious here, either.
Is there anything else I should look for, or is that all I can do for a cursory inspection?
Thanks
