88 to 95 or 96
Old Jun 3, 2010 | 07:44 PM
roadgliderick's Avatar
roadgliderick
Default 88 to 95 or 96
i need u guys help i have a stock 96 top end barrels, heads ,pistons and cams. off a 2009 streetglide could this set up be installed on a 2002 roadking with out many changes. cuz this friend wants to buy my old top end. help!!!!!
Old Jun 3, 2010 | 07:52 PM
dawg's Avatar
dawg
cylinders and heads yes, pistons and cams no
Old Jun 3, 2010 | 07:56 PM
roadgliderick
dawg what piston and cams would he need. thanks i new i would here from u.
Old Jun 3, 2010 | 08:12 PM
Ghosty's Avatar
Ghosty
I'm not trying to horn in but I was hoping someone could answer a quick question for me. Just how far can an 88 be taken to. I know they'll go to 95 ci. will they go bigger? Thanks for any info you folks can provide.
Old Jun 3, 2010 | 08:15 PM
byersmtrco's Avatar
byersmtrco
You would gain nothing.
88" & 96" piston (bore size) is the same.
96" was achieved w/longer stroke.
Using the same size big bore kit that will make
an 88 a 95 will make a 96 into a 103.
Confused yet?
Myself I like the shorter stroke config of the 88.
Bumping to 95 seems like a good solid (more square)
eng config.
I'm sure the 96's run good (only ridden a couple demo
Street Glides) the one with the stage 1 seemed ok.
The stk one was a gutless wonder. But un-do all
the epa garbage . . .
Old Jun 3, 2010 | 08:24 PM
roadgliderick
Confused yet?
eng config.
so dont even bother wasting any time huh! ok well i truely appreciate your input. this will take the air right of him he was hoping to build his motor on a low budget. any how thanks.
Rick
Old Jun 3, 2010 | 08:38 PM
wlbowers's Avatar
wlbowers
You do know the jugs on a 96" are the same size as the jugs on an 88".
The 96" motor is stroked from the 88's 4" to 4.375".
I have heard of people taking the 88 jugs to 3.875. That gives you 95".
Old Jun 3, 2010 | 09:22 PM
mudrat454's Avatar
mudrat454
You can take an 88 to a 98 with stock cylinders bored to 3.938
Old Jun 3, 2010 | 09:26 PM
dawg's Avatar
dawg
Depends on if you're talking about just boring the cylinders or not. You can take an 88 to 120 and beyond by splitting the cases, working the crank, etc. There is a 98 kit available.
Old Jun 3, 2010 | 09:38 PM
Ghosty's Avatar
Ghosty
Thanks for the info guys.
03Custom883
Nov 5, 2017 07:50 PM
Shrink
Engine Mechanical Topics
Apr 28, 2015 03:56 PM
gaslog4
Jan 6, 2015 08:46 PM
nosillyname
Exhaust System Topics
20
Dec 13, 2010 08:16 PM
cmashark
Sep 20, 2009 09:56 AM
