HD air shocks bleeding air - any fix?
Old Jun 4, 2010 | 01:44 PM
prufrock28's Avatar
prufrock28
Default HD air shocks bleeding air - any fix?
I recently purchased a 2010 Road King. The rear air shocks don't seem to be able to hold air. I've tried a variety of levels between 10-50 psi and within a few days, it seems I only have about 40%-60% of what I originally put in. Is this common? Is there a dealer fix?
Thx!
Old Jun 4, 2010 | 01:51 PM
emwolb's Avatar
emwolb
and that's why they invented the concept of warranty. if the air shock system is leaking, let them take care of it for you. once you trying to fix it yourself, you may be on your own. hey man, it's a new bike, swing into the dealership and let them know about it so they can fix it. this is a no brainer. by the way, welcome to the forum.
emwolb's Avatar
emwolb
emwolb's Avatar
emwolb
Old Jun 4, 2010 | 02:13 PM
Road Ranger's Avatar
Road Ranger
What did you use to add air to the shocks? If you used an air compressor you probably blew out the seals. Harley makes a decent pump just for that purpose for about 50 bucks.
Old Jun 4, 2010 | 02:15 PM
Jags93's Avatar
Jags93
What are you using to check the pressure? If you are using a regular air gauge you are probably losing a lot of air when you release the gauge from the valve. The system hold a tiny volume of air and it makes a difference if you don't use a no-loss gauge or pump.
The Harley pump/gauge is excellent.
Old Jun 4, 2010 | 02:18 PM
Jags93's Avatar
Jags93
This one:
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Jun 4, 2010 | 02:56 PM
frog13's Avatar
frog13
It's a 2010, you should just take it in. If you are airing it with a compressor, good chance you blew a seal. If you are checking with a regular gauge, as said, you are probably losing the air when you remove the gauge. If you feel the need to work on it yourself, the first thing I would do is remove each fitting and reinstall it, I've seen a couple that have been loose. It takes all of five minutes to do them all and can't hurt anything. Remember, if you don't have the right pump, the shocks will be empty after you reinstall the fittings, you'll either have to ride to the dealer with no air or get a pump.
Old Jun 4, 2010 | 04:10 PM
skcm2006's Avatar
skcm2006
Smile
I have an 09 Street Glide, I had the same issue - it was the shrader (spelling) valve. They turned it an 1/8th of a turn and it was good as new.
Plus one on the HD pump - it is a little expensive but works great.
Old Jun 4, 2010 | 04:30 PM
DamnFool's Avatar
DamnFool
Blew a seal! its ice cream - I Swear!
I will sell my 06 streetglide air shocks for cheap....
