Leaking Front Master Cylinder Lid
Old Jun 6, 2010 | 05:38 PM
atrain68's Avatar
atrain68
Default Leaking Front Master Cylinder Lid
It doesn't matter how tight my master cylinder reservoir lid is, it still leaks when I apply the front brake. I had this issue over a year ago and replaced the lid and rubber seal underneath. That worked for awhile it started leaking again. Suggestions?
Old Jun 6, 2010 | 06:03 PM
shagnasty's Avatar
shagnasty
06 model. stock black and chrome both leaked. I tried tight loose and in between. nothing works so far.
Old Jun 6, 2010 | 06:09 PM
shortride's Avatar
shortride
The front master cyliinder on my '09 Ultra Classic seeps a little.
Old Jun 6, 2010 | 06:20 PM
tj316's Avatar
tj316
I replaced mine with a chrome one from drag specialties, it's like $97, looks good ,no leak
Old Jun 6, 2010 | 06:31 PM
dawg's Avatar
dawg
They are not supposed to leak. Will bubble the cylinder paint. Try and replace it with the lid/gasket kit (be it the black kit or the chrome kit) and if it still leaks you will probably need a new master. They had updated the Brembo lid and gaskets because of the leaks. What pn# was your replacement lid when you had it put on?
Old Jun 6, 2010 | 06:38 PM
dawg's Avatar
dawg
The updated kit number is 42855-06B. If you got the -06A as a replacement over a year ago, that's why it still leaks.
Old Jun 6, 2010 | 06:50 PM
atrain68's Avatar
atrain68
Thanks Dawg. I'll order the updated part number. I appreciate the help.
Old Jul 3, 2010 | 06:40 PM
r46jack's Avatar
r46jack
How did you get on with the new lid, mine started seeping today.
Old Jul 3, 2010 | 07:25 PM
blackrever's Avatar
blackrever
Also had a leak on my 09' master dealer replaced new gasket under warrenty.
Old Jul 3, 2010 | 07:30 PM
soos's Avatar
soos
I had both my upper and lower covers replaced in June under warranty. Still cost me $50.
