Any tips on 21/18 install
Old Jun 16, 2010 | 01:11 PM
rome304's Avatar
rome304
Default Any tips on 21/18 install
I will be buying new rims before the 4th of july and i wont to install myself have the floor jack and plenty of tools any tips on this swap from stock 16's is appreciated thanks rome.
Old Jun 16, 2010 | 01:21 PM
WideBoy04's Avatar
WideBoy04
Shouldn't be a problem. Calipers are easier to install
with 18's. I tend to strap down the bike when working
on both wheels. Your manual will get you through. Be
prepared for a different feel with the 21" front.
Jim
Old Jun 16, 2010 | 01:28 PM
dan11809's Avatar
dan11809
Something will happen that you aren't ready for.What size tire will you be running in the rear? You need the right size hub or spacers.
Old Jun 16, 2010 | 01:49 PM
rome304's Avatar
rome304
Front rim 21x3.25 rear rim 18x3.50 tires i will buy tires seperate to fit i talked to the guy selling me the rims he said he will provide proper hubs i guess i will have to purchase additional spacers any advice will help.
Originally Posted by dan11809
something will happen that you aren't ready for.what size tire will you be running in the rear? You need the right size hub or spacers.
Old Jun 16, 2010 | 02:11 PM
dan11809's Avatar
dan11809
You should be o.k. If you run a 160 it gets harder.
Old Jun 16, 2010 | 03:27 PM
rome304's Avatar
rome304
Thanks i'll check the search for any other tips.
Old Jun 16, 2010 | 09:47 PM
103Eagle's Avatar
103Eagle
Most likely with the 21 front combo you will have fender clearance issues. Most people tape a 1/4 to 5/16 thick nut onto the center of the tire and spin the wheel. If it rubs you have to add clearance. By drilling out both rear fender bolt holes you can then tip the fender forward by lifting up on the bottom of the rear of the fender, thus tilting it foreword. In most cases this will give the proper clearance. Some brands of tires expand more than others while riding. Plenty of post here about this issue, the tire expands, rubs the inside of the fender and blisters the paint. Good Luck.
Old Jun 16, 2010 | 09:56 PM
roborob's Avatar
roborob
Thumbs up
I've had no problems with my 21 in front on 08 SG. I'm running Metzler tires. I love the feel of 21 up front.It felt odd at first but I hardly notice it now . They look good. Good luck
Old Jun 18, 2010 | 10:45 AM
rome304's Avatar
rome304
thanks for the tips.
DHOLT
Aug 18, 2013 07:42 PM
raceroni06
Nov 25, 2012 08:19 PM
DirtNap
Sep 18, 2011 12:01 PM
jpnelson1978
Oct 18, 2009 03:45 AM
Manish_Hawg
Apr 23, 2008 08:28 PM
