thought I'd try my hand at wrenching today...just got my HD manual afterall. Bikes got 24,000 miles (bought it with 21,000) so I thought I'd check the 15 engine mount bolts for tightness.
Followed the steps for purging the fuel supply lines. Good so far. disconnected the negative; cut cable strap around harnesses; and removed to bolts from console. Good so far. Disconnected fuel level sender, fuel guage, and fuel supply lines. Good again. Removed front bolts then back one. Propped tank on backbone. TIGHTENED 2 BOLTS AND FREAKED! Immediately had my brother help put it back together. Just couldn't handle it being apart like that. Was thinking, oh sh#t! This thing is never going to start again!
Nervously got it all back together and she runs fine. After a couple hours now, I am thinking....ok, that wasn't soooooo bad. Maybe, just maybe I'll try again someday.
Sounds like you did OK. You paid attention to detail and remembered exactly how to put it back together, GOOD JOB!! The Parts Manual gives you a very good break down illustration of the bike to see how something goes together, that might be helpful if you choose to go further.
If you don't, don't sweat it. Do what you feel comfortable doing. Wrenching isn't necessarily for everybody, that's why there are a bunch of good Indy's out there as well as mechanics at the Dealer.
I was the same way at one time, it'll grow on you. Give me a scattered out two stroke motor, blindfold and a set of metric wrenches and I can build a working engine. Four stroke, not so much (too many moving parts). That said, last winter I put 255 cams in my wife's bike, bought a air lift (handy's B.O.B. 1500) tire changer (no mar pro jr) and do all my own work (except electrical where I am still illiterate). Keep practicing.
I know the feeling. I presently have an entire banquet table covered with parts, bolts, gaskets, O rings and implements of destruction (tools) of every shape and size. I'm doing a big bore kit, cams, cam plate upgrade and probably shifter arm seal replacement all in one massive attack.
Either Murphy will win, or I will. Time will tell.
Mom said I started taking stuff apart about age 2 so I guess it's in my blood. Growing up on a SE GA farm in the 60's and 70's you very rarely hired anyone to do anything. Either you figured it out or found someone to ask questios of.
Grew up around a bunch of old school bikers who's thinking was, "if you can't work on it, you don't need to be riding it".
Today at almost 50, almost nothing mechanical or electrical scares me. However, I am not too proud to ask for help. Someone once said, "The only stupid question is the one you didn't ask"
Hang in there and work at it slowly. Take pictures, make diagrams, whatever your method is for figuring things out and ask for help when needed. Oh, make sure you use good tools also. I have seen many screwups by knowledgable people using cheap tools.
Forums like this are wonderful with so many experienced people to solicit advice from. Wish they had been around in the middle 70's when I had my Suzuki GT750 in a million little pieces replacing a burned piston!
Good for you. I started my mechanics at an early age on lawnmowers. Actually paid for my first bike while mowing lawns and repairing lawn mowers. If you can read a book, buying and using an HD service manual is the best investment a rider can make.
It gets addicting. I think the most important lesson to learn is to take your time. If something isnt going right, you must have the discipline to walk away and come back later. Forcing things generally results in problems, trust me, thats experiance talking.
