Bad starter?
Old Jul 7, 2010 | 10:54 AM
King SS's Avatar
King SS
Default Bad starter?
So I blew the belt on my 01 rk a while back, and finally had time to get it back together. I went out to fire it up yesterday and the starter started clicking, like the battery was dead. So I threw the charger on for a while, tried again and still the same thing! I pulled the primary cover off to make sure that the starter is engaging, and it is. It seems like it doesn't have enough to crank the motor over. What gives?
Old Jul 7, 2010 | 11:31 AM
twincam47's Avatar
twincam47
check your ground cable that is attached to the starter mounting bolt???? Loose????
Old Jul 7, 2010 | 02:15 PM
King SS's Avatar
King SS
Twincam you were right! The way I had the ground tucked out of the way I didn't even notice that I hadn't hooked it up. My stupidity!! Thanks brother.
Old Jul 7, 2010 | 02:52 PM
SG Mike's Avatar
SG Mike
Check your battery voltage.
Old Jul 7, 2010 | 08:10 PM
BLKBAGGER's Avatar
BLKBAGGER
I always thought is was a **** poor design that you have to loosen the starter bolts to pull the inner primary. I have seen plenty of people forget to tighten them.
Rescuediver1982
EVO
Jul 28, 2015 08:39 PM
WVICEMAN
EVO
Nov 9, 2014 07:36 AM
pjb
EVO
May 8, 2012 07:15 AM
bwanas
Oct 22, 2009 09:21 PM
fatbob
Jul 25, 2008 10:39 PM
