Batwing fairing vibration
Old Nov 15, 2024 | 06:41 AM
joninte2's Avatar
joninte2
Stage I
Very true, if the windshield height isnt enough for the height of the rider it's going to be more uncomfortable than no windshield at all as it'll just angle the air and blow it directly into your face or up under your helmet making it feel like it's going to jump off your head. Very uncomfortable feeling.
Old Nov 15, 2024 | 04:57 PM
Kozmo's Avatar
Kozmo
I am replacing my verticle supports tomorrow.
Old Nov 19, 2024 | 08:22 AM
Mongo1958's Avatar
Mongo1958
I removed the outer fairing and found the bottom mounts on the outer fairing cracked around the brass inserts. The cracked mount on the clutch side was large enough for the brass insert to fall out. The bottom screw ports of the inner fairing had stress cracks as well. I didn't take pics of the cracked ABS plastic parts but here are the pics after I repaired them. The brackets and the vertical supports, all looked good with no broken parts.
I've already made up my mind that I'm going to get a new inner and outer fairing. However, I'm hoping that this repair will last until then.
Old Nov 19, 2024 | 11:23 AM
HD Bobber's Avatar
HD Bobber
I'll be replacing the big long brackets on mine this winter with HD's updated units since inner fairing is getting painted.
  • Left Fairing Support Bracket (#17): 58478-96B
  • Right Fairing Support Bracket (#18): 58479-96B
Basz
Sep 26, 2015 07:50 AM
luisan
Oct 2, 2012 09:16 AM
MyFirstHD
Jun 11, 2012 12:01 PM
Nute
Mar 17, 2012 07:52 AM
Streetrunner
Jun 3, 2008 09:31 PM
