saddle bag latch stuck!
Old Jul 9, 2010 | 02:51 PM
jtb4ever's Avatar
jtb4ever
Default saddle bag latch stuck!
09 streetglide.. saddle bag latch gettin stuck on ocassion when i lock them. when i unlock them and then try to close the latch it will not close..took it to dealer today they ordered brand new locking mechanisms keyed to my bike. just wonderin if anyone had same issue..thanks!
Old Nov 2, 2011 | 03:54 PM
michaelvs710's Avatar
michaelvs710
seems like a common issue
Old Nov 2, 2011 | 04:02 PM
hopperop's Avatar
hopperop
The nuts are probably loose. they should be just a little past finger tight. To tight and they won't work at all, to loose and they jam and turn to far. Finicky little SOB things.
Old Nov 2, 2011 | 04:44 PM
frog13's Avatar
frog13
I've seen that issue on several bags where the latch just won't shut. It had nothing to do with the lock itself, the tab that locks the bag would interfere with the plate it has to move through to close the bag. If you get under there and watch it real close when it won't close you will see where it is hitting. First time I saw it the guy filed off a little bit of the tab and cured the problem, but when he locked it, it wasn't very secure. The next time I saw it, we decided to dremel out the plate a little, problem solved. I've done several others that have had the same issue, it is a very minute amount. I just lived with mine, whenever it hung up, I just reached under and touched the latch, it moved just enough to close easily.
Old Nov 3, 2011 | 01:33 PM
Jon 2005 Road King's Avatar
Jon 2005 Road King
My bags have a similar issue. It's the pin that threads through and connects the two half pieces of the latch. The pin itself tends to vibrate and slide out, which pins the latch closed. A small dab of lock tire on the end of the pin solves the problem.
Ozark Joe
EVO
Jan 22, 2016 08:13 PM
blackflame
Jul 26, 2012 09:27 PM
14longshot
May 24, 2012 04:16 PM
Mountainkowboy
Mar 29, 2012 05:43 PM
08 geezer glide
Sep 4, 2011 06:44 AM
