Low Idle on 01 RK
Old Jul 9, 2010 | 04:23 PM
Bigdaddy_60's Avatar
Bigdaddy_60
2nd Gear
Default Low Idle on 01 RK
Hey Gang
My 01 RH (fuel Injected) has developed a problem when its warmed up and you stop it Idles so low it almost stalls. When it's cold it's fine.
Any Idea's
Big Daddy
Old Jul 9, 2010 | 06:52 PM
cpotts454's Avatar
cpotts454
Increase your low idle. All you need is a torx bit set and some other basic tools. Here is a link to the how-to.
Do you have an RPM gauge? Its really hard to tell the difference between 800 and 1000 rpms without it. I set mine right at 1000 rpms... Just doesnt sound much like a Harley anymore, but it runs great now.
Old Jul 16, 2010 | 01:09 PM
Bodean46's Avatar
Bodean46
My 01 Ultra was doing the same thing and discovered fuel regulator was bad and had a kink in return line allowing fuel pressure to hold at 75lbs instead of 45. replace fuel pump, regulator, and hoses in tank and all is well again.
Huggerbugger
Aug 1, 2018 07:52 PM
bezzeghdenes
Oct 24, 2013 11:46 AM
glide2005
May 25, 2009 04:06 PM
HDF Tech
General Topics/Tech Tips
Aug 12, 2005 09:32 PM
HDF Tech
Aug 12, 2005 09:24 PM
