Low beam blown?
Old Jul 10, 2010 | 09:53 PM
brew1967's Avatar
brew1967
Stage I
Default Low beam blown?
Hey Everyone, I have a 2008 Road King 105th Anniversary edition, belong to an MC, do a lot of riding and this has me baffled. We were leaving a gig and a brother noticed my headlight was out, my spots were on of course, so I threw on my high beams they came on but the spots went out. I have darn near tore the bike apart tonight and found nothing wrong. Another friend called and said that he believes the spots run across the low beam circuit when the highs are on and vice versa, and if the low beam was out it should produce this problem has anyone heard of this? Thanks Keith aka Cobbler
Old Jul 10, 2010 | 09:57 PM
dawg's Avatar
dawg
Spots only work with low beam so if spots were on and headlamp was not, but headlamp came on when high beam turned on and spots went out, then yes you need to replace the bulb as the low beam is gone.
Old Jul 10, 2010 | 09:58 PM
BackRoader's Avatar
BackRoader
Not exactly sure what your problem is, but the "passing lamps" do run only on low beam. Switch to high and out they go.
Old Jul 11, 2010 | 07:10 AM
Mick's Avatar
Mick
Welcome to the forum Keith.
The headlight bulb is a dual filament bulb.
The low beam filament is shot , just replace the bulb.
In the "stock" configuration , the passing beams will only work with the low beams.
This would be normal.
Mick
Old Jul 11, 2010 | 09:40 AM
CROCKETT's Avatar
CROCKETT
The spots only work when when headlight is on low beam, your low beam headlight is definitley burnt out!!!
Old Jul 11, 2010 | 09:47 AM
CROCKETT's Avatar
CROCKETT
Sorry MICK didn't read your post, you are so correct!!!
6 gun
Apr 25, 2018 05:41 AM
Sal C
Jan 25, 2017 12:45 PM
MichiganDave
Jul 25, 2012 09:01 PM
brickie
Jun 5, 2009 11:51 AM
Marblemania
May 25, 2007 09:59 AM
