if I have my cylenders deck height adjusted will the stock rods still fit?
Depends on how much the shop shaves off. They make "perfect fit" pushrods. They are non adjustable and come in various lengths. Check the SE catalog on the HD website.
Having used adjustables on my Panhead and my stroker shovels, I would stick with the stock. One less thing to worry about. Everytime you hear a noise you'll be pulling the pushrod tubes open to check them.. If I go with cams on my bike I'll take the extra time to lift the tank and remove the rocker boxes.
Thats my 2 cents...
with a caveat... You can use the stock pushrods in that way only if the base circle for the new cams matches the old... Otherwise, you need to make them the right length for the new cams anyway.
Dalbergia ...yeah, good call on the base circle. I guess I need to check that on the Woods 6-6 cams. Anyone running stock (non-adjustable) pushrods with a Woods 6-6 cam install?
Lots of great feedback on this thread (as always at HDforums.com), thanks Dudes! However, there is obviously 2 philosophies reporting here. So, I guess I just have to make a "command decision" and live with it. My inclination is to "error on the safe side" ...do the extra work, use the non-adjustable pushrods, and hopefully sleep better at night. I guess if I were going to play "musical cams" like one rider posted, I'd do the adjustable pushrods. But I'm pretty sure I'm going to be satisfied with the TW6-6 cams. Besides, its a long cold winter in Alaska, so I will have plenty of time to tear into it.
Any other input on this? Keep the feedback coming!
