2000 Ultra Classic
Old Jul 15, 2010 | 04:33 PM
harley1515's Avatar
harley1515
Stage II
Cool 2000 Ultra Classic
I was riding home yesterday, temperature was about 98. I started hearing a high pitched roar at 50-60 miles per hour when I backed off the throttle and then accelerated slightly. The noise probably didn't go away when I continued to advance the throttle; I probably couldn't hear it over the exhaust. Almost sounded like something inside the right side of the engine. I didn't notice the sound until the engine got warmed up good.
Old Jul 15, 2010 | 04:37 PM
Seminolebagger's Avatar
Seminolebagger
Have you checked your cam chain tensioners? If they go, metal to metal could sound that way. Not good.
Old Jul 15, 2010 | 10:30 PM
harley1515's Avatar
harley1515
Stage II
I was thinking about that but it only has 11K miles. I didn't think they would be that worn with this low mileage??
Old Jul 17, 2010 | 09:08 AM
Hx3's Avatar
Hx3
You should pull your axles out and check them. Had this exact problem on my 03 and found both axles were dry/galled and were causing this. Had to replace the rear axle. Make sure you lube it well with anti-seize if that's the problem.
TSD
May 26, 2013 08:17 PM
Dresser Dan
Exhaust System Topics
Mar 5, 2013 01:59 PM
jojo b
Jun 19, 2011 10:25 AM
brianseay
11
May 11, 2011 10:09 PM
mhultman
Nov 4, 2005 07:27 AM
