strange lighting???
Old Jul 19, 2010 | 10:47 AM
Dallas ROADKING's Avatar
Dallas ROADKING
Stage I
Default strange lighting???
I have a 2007 rk classic and have removed the driving lights and factory turn signals. I replaced them with bullet style turn signals. Yesterday after I returned home from a ride, I notice In the reflection of my truck, that when I pull the front brake lever my right front signal light turns off and some times both of them. All of the wiring looks good but I am wondering if there is a signal switch or some thing that could need to be replaced? When I went out this morning to check it again, it was working fine. ANY SUGGESTIONS??
Old Jul 19, 2010 | 11:05 AM
drukanfu's Avatar
drukanfu
Double check your wire connections, seems that if all the wires arn't togeather just perfect, you get a different draw. Give it some time though, might just have to settle in, with all the electronics now-a-days.
Old Jul 19, 2010 | 11:25 AM
vzts4q's Avatar
vzts4q
Default probaly a gound
Normally this type of problem is a grounding issue. Start by checking any grounds you may have changed when doing the lighting swap
splattttttt
Electrical/Lighting/Alarm
Jun 29, 2019 01:41 PM
Tack57
Jul 10, 2018 09:22 PM
JMBuck
May 22, 2013 04:59 AM
rroyster
Apr 22, 2008 06:58 PM
95custsoftail
Jun 7, 2007 11:03 AM
