one more clutch adjust question
Old Jul 20, 2010 | 02:27 PM
WILLETTS's Avatar
WILLETTS
Default one more clutch adjust question
After finding the sweet spot with the allen wrench, when turning the adjuster screw back the 1/2 to 1 turn. Which puts the handle closer to the bars the 1/2 turn or the full turn ?. Mine seems a little to far out when it finally grabs.
Also a quick question about the easy adjust method. It says to collapse the cable and then hold the lever against the bar, turn the adjust screw cw until the lever starts to move away. Then back out 1/2 turn.. On mine that is a good 3 turns farther in then doing it the manual way. Anyone else notice this ? When doing the manual way Im guessing the lever is all the way out ?
I've read and adjusted several times but still get just a little slippage in 6th under a good load.
Old Jul 20, 2010 | 02:54 PM
bentryder's Avatar
bentryder
Here's what i do....after findin the "sweet spot" as you call it....i back out the screw about 3/4 of a turn and lock it...then reset the clutch cable with the amount of play needed to get the friction zone where you like it....done....i don't adjust the allen screw to move the clutch lever...
Old Jul 20, 2010 | 03:00 PM
toad6301's Avatar
toad6301
+1 to that , I back off 1/2 turn and lock
it down, then adjust the cable to get
the correct free play.
Old Jul 20, 2010 | 03:26 PM
nvsteve's Avatar
nvsteve
A full turn and the clutch will grab sooner off the bar. I use 3/4 doing it the old (book) way.
Old Jul 20, 2010 | 08:20 PM
weekendwarrior's Avatar
weekendwarrior
yep, 3/4 of a turn and ALWAYS adjust the cable for freeplay, not the bolt and jamnut
Jim Dawson
Sep 16, 2013 12:41 PM
TedMan
Nov 5, 2012 04:17 PM
RZA
Feb 3, 2012 02:43 PM
BlackFLHR
Nov 29, 2008 09:10 AM
JollyRogers
Sep 9, 2006 10:47 AM
