Spark Plug Wires Stock VS SE
Old Jul 23, 2010 | 08:15 AM
Theakerr's Avatar
Theakerr
Default Spark Plug Wires Stock VS SE
A while back someone posted a note that he replaced his spark plug wires every two years using Screaming Eagle wires (It was in another thread so I haven't been able to find it using the search engine). If that person reads this thread, how did you manage to get the 360 degree turn in the front cylinder wire since the SE wires will not fit in the clamp/holder. Is there a holder to fit the thicker SE wires. I ended up putting stock wires in because there are so many wires/cables in the tank tunnel area and I didn't want to run the risk of the plug wires fraying if they were not held in place by the clip
Old Jul 23, 2010 | 11:10 AM
hougz79's Avatar
hougz79
My SE Wires went in just fine on the stock clips.
Old Jul 23, 2010 | 05:02 PM
Theakerr's Avatar
Theakerr
I see your bike is a 2010, I wonder if the clips are bigger because there is no way the SE wire would go in the 360 degree turn clip in my 2003. The two straight ones yes!
Old Jul 23, 2010 | 06:15 PM
Egldr05's Avatar
Egldr05
It wasn't easy but I made it work on my 05.
Rick
Old Jul 23, 2010 | 07:02 PM
Sancho's Avatar
Sancho
My SE went in with a little coaxing. But buying the SE in my opinion after using them myself is a waste of money. I have a 2010.
Old Jul 23, 2010 | 07:41 PM
trackadaptor's Avatar
trackadaptor
Wink Link
Here you go:
https://www.hdforums.com/forum/touri...ney-spent.html
Old Jul 23, 2010 | 07:48 PM
hougz79's Avatar
hougz79
Yeah, no gain in performance at all.... but I like the orange accent it adds.
Old Jul 23, 2010 | 08:27 PM
Certified Drunk's Avatar
Certified Drunk
In the bang for the buck meter.....waste of money!
Old Jul 23, 2010 | 10:29 PM
nytryder's Avatar
nytryder
The SE plugs and wires are designed for race motors. In a stock motor they can cause firing issues.
Old Jul 24, 2010 | 12:11 AM
trackadaptor
Default hmmmmm
http://www.ultimaproducts.com/plugs.htm
2 - 8 hp increase over factory OEM wires. Every wire factory tested for quality and reliability.
The Ultimate in spark plug wire technology, 8mm plus
40 ohms of resistance per foot, which gives the highest spark energy transfer and the highest EMI/RFI supression. KevlarŽ core center with a nickle copper alloy conductor wire, which is wound 124 times per inch. This type of center conductor is
a slightly smaller diameter allowing for an increased
amount of premium EPDM insulation material. The use
of KevlarŽ produces a core that has four times the
strength of other aramid fiber cores resulting in a very
high tensile strength from a small diameter. the insulated
core is braided with high strength fiberglass strand for
improved resistance to terminal pull off.
The jacket is a high quality silicone product resisting
temperatures up to 600°F. Highest quality silicone spark plug
boots and coil boots. Posi-snap lock stainless steel spring clip terminals. Dyno-tested, resulting in 2 - 8 hp increase over factory OEM wires. Every wire factory tested for quality and reliability.
Wire sets come complete and ready for installation.
