Compensator Nut
Old Jul 23, 2010 | 03:00 PM
TRVSDAD's Avatar
TRVSDAD
Default Compensator Nut
Just spent 400.00 to replace rotor (?) after the compensator nut came loose and tore out the splines. Any idea why the compensator nut came/comes loose. Seems it has happened to many riders. Why isn't there a retaining clip of some sort to prevent the damage from getting worse as it loosens up?
Old Jul 23, 2010 | 03:10 PM
89FLHT's Avatar
89FLHT
they get loose if there was not enough torque applied correctly the first time or even if there was, if shims are to thick and it bottoms out without fully seating.
Best to grab the FSM - measure the stack hieght of the compensator and shims, make sure they are within spec, clean the shaft, threads and the nut completly. apply red loctite and use the proper torque wrench and proceedure in the FSM to make sure your good to go.
Old Jul 23, 2010 | 03:15 PM
TRVSDAD's Avatar
TRVSDAD
I had a chrome inner primary installed when the bike was almost new, maybe the tech did not tighten it properly (if he had to remove it to put on the new inner primary). I can only hope the latest tech did as you described above with the shims and red lock-tite.
Old Jul 23, 2010 | 04:06 PM
harry.b's Avatar
harry.b
He did have to remove it to put on the new inner primary. several things can go wrong if the tech takes a short cut. To do the job right, both compensator nut and threads on the output shaft have to be spotless and free of any oil and residual loctite. It took me a while to thoroughly clean mine. Also, if the tech didn't use any lock tite accellerator, then the bike should have sat for at least 24 hours to let the loctite cure. Even if the tech did torque to specs, but got sloppy on the previous steps, the loctite would not have held. Sorry for your bad luck.
Old Jul 23, 2010 | 05:25 PM
threeten's Avatar
threeten
There have been a lot of posts about compensator nuts lately.
Did you have any warning before it broke loose? Excess vibration? Just like to know what to look for.
Old Jul 23, 2010 | 05:31 PM
Badfinger's Avatar
Badfinger
The only warning I had was a clattering noise when letting the clutch out, almost sounds like the jiffy stand hitting the bottom of the bike.
Old Jul 23, 2010 | 05:52 PM
TRVSDAD's Avatar
TRVSDAD
A very minor grind, very intermittent, could not replicate it. Some times it took two blocks to happen, then not again for 80 miles only lasted about two seconds. Tech said I was lucky it didn't fail and leave us stranded that 80 miles from home.
Old Jul 23, 2010 | 07:20 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Default Nut
Just my opinion but I do not think the nut on at least 04 on needs to be loose to stripe the narrow spline. Some hard driving and downshifting will wring it off. After all it is a very small spline and just a little narrow spacer on the face. When I replaced mine the part man said as best I can remember the had sold ten in the last year. Check my grf000 pictures and my write up. Mine stripped out and the nut was still locktite frozen and was being driven by the compensator spring. The newer bikes have gone to a seration like the clutch drive which should be much stronger. Not sure which years but my 04 has a 10 spline
eagles350
EVO
15
May 6, 2014 09:49 PM
robvg
Mar 26, 2013 07:51 PM
96roadking
EVO
34
Feb 21, 2011 05:09 PM
TRVSDAD
Jul 28, 2010 11:38 AM
79lowrider
Oct 2, 2008 08:10 PM
