Help installing Fatcat
Old Jul 25, 2010 | 11:43 PM
SA315B's Avatar
SA315B
Default Help installing Fatcat
Looking for a D&D Fatcat installation video or instruction sheet for a 2008 touring frame.
Old Jul 25, 2010 | 11:50 PM
1bad09sglide's Avatar
1bad09sglide
Its on their website
Old Jul 27, 2010 | 12:20 PM
SA315B's Avatar
SA315B
I have been all over their web site several times. If there is a video of a fat cat installation they hide it well.
Old Jul 27, 2010 | 12:36 PM
dawg's Avatar
dawg
FWIW, when I installed mine at first I think I did it wrong and it ended up that the pipe was rubbing on the arm and piston of the brake lever and it almost wore through the pipe. It also was up too high and was close to hitting my RJ Originals heat shields. I shipped the pipe back to them and they gave me a new one (still without proper instructions) so I installed spacers behind the bracket that attaches under the tranny side cover and it made things much better (got it away from the rear brake pedal and sits right when under the heat shields).
Old Jul 28, 2010 | 04:06 PM
SA315B's Avatar
SA315B
Does the heat shield completely cover the pipes or is some of the header exposed?
Old Jul 29, 2010 | 12:13 AM
Northside's Avatar
Northside
The heat shields fit perfectly on my '07. If you haven't got it on yet here are a few tips. Install the system without tightening anything. Install the tranny mount a little loose, a 1/4 inch Allen wrench with a cut down short arm will make tightening that tranny mount easier after the exhaust is lined up and you're tightening everthing. Use a dab of anti sieze an the flange studs, the two 1/2 long black spacers go on top of the standoffs on the muffler. Tighten everything from back to front. Oh yeah, make sure the muffler clamp is flush with the front end (inlet) of the muffler. Tighten the clamp to 150 in. lbs. If you dont have that clamp positioned right the muffler can slide back (has happened to a lot of guys) and the bell shaped heat shield wont slide forward far enough to meet the headers heat shields.
Old Jul 29, 2010 | 01:11 AM
1bad09sglide
http://www.danddexhaust.com/catalog/install/549-32.pdf that is the direction sheet on the website.
Old Jul 29, 2010 | 09:26 AM
Northside's Avatar
Northside
That's for the Boss Fat Cat. His bike is an '08 and uses the original Fat Cat. I think the tab goes on the bottom of the transmission mount and D&D supplies a new mount with that pipe.
Bodacious MC
Apr 5, 2020 11:42 AM
20SOS
Jul 30, 2016 03:59 PM
Time2ride
EVO
Jun 17, 2012 04:13 PM
Good_Apollo
Oct 2, 2011 08:07 AM
CSRflstc
Dec 13, 2009 11:59 PM
