SE Compensator
Old Aug 2, 2010 | 11:39 AM
  #41
boom23's Avatar
boom23
Chicago Harley has it (part # 40274-08) for $199.96 + shipping.
Old Aug 2, 2010 | 12:24 PM
  #42
nemick's Avatar
nemick
I went ahead and bought the SE Compensator this past Saturday. My local dealer had an open house and everything except bikes were 20% off. I'll be installing in the near future and will report my thoughts.
Old Aug 2, 2010 | 03:54 PM
  #43
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
That's a smokin deal!
That's less than our cost through Harley, but what are they charging for shipping?
Shawn
Old Aug 2, 2010 | 05:19 PM
  #44
HOGNOT's Avatar
HOGNOT
Originally Posted by nemick
The Screaming Eagle Compensator is the engines front chain sprocket and electrical stator mount. It is designed to mitigate some of the vibration and engine pulses which are fed into the drivetrain by means of a pre-loaded cam and ramp system. Essentially, the SE version can handle up to 8 times the load of the stock version and hopefully, in my case, reduce some of the clatter coming out of the primary case. The item lists at $250.00 and I don't know what labor would cost as I do my own wrenching.
I recently had compression releases installed on what was a 103" but was turned into a 107" during the compression release install. I was told by the mechanic doing this work that he suspected the compensation "spring" was broken due to a loud clank he could hear when shutting down the engine during the several dyno runs he did. I agreed to the approx. $400 repair......don't know if I got the standard or the SE version. Anyway he showed me the part and sure enough it is a spring and it was broken. The spring and housing surrounds the rotor....still don't understand what it's for.
I didn't hear the "clank" before this work was done and still don't....sheesh.
VR
Old Aug 2, 2010 | 05:49 PM
  #45
tincup64's Avatar
tincup64
subscribed
*Road King*
Nov 11, 2018 06:03 PM
1st 96 ultra
Nov 10, 2012 06:47 PM
P51Driver
Aug 24, 2012 08:12 PM
jbmss
Aug 14, 2011 04:57 PM
crazzy76
Jun 29, 2011 06:17 PM
