Bub 7 question
Old Aug 2, 2010 | 02:16 AM
Born2cure's Avatar
Born2cure
Default Bub 7 question
I have a set of bub 7 td on my 08 ultra I'm wondering if the baffles can become loose seems like I have a high pitched rattle. Might be the baffle not sure I have tightened everything down. If they loosen up how can I secure it.
Thanks
Old Aug 2, 2010 | 09:22 AM
highwayking's Avatar
highwayking
Have you sprayed the rubber muffler mount grommets with silicone spray yet? Give it a try, you might be surprised to find that the high pitched rattle is actually a squeak that is caused by the vibration of the mufflers. If this doesn't work, then make sure your heat shields are good and tight. I really doubt that there would be an issue with the baffles being tight.
Old Aug 2, 2010 | 10:03 AM
Born2cure's Avatar
Born2cure
Thanks highwayking didn't think it was the baffles but couldn't think of anything else. will try the spray. Already secured the shields and mounts.
Old Aug 2, 2010 | 11:04 AM
SteveO's Avatar
SteveO
Yes, over time the baffles will rattle in both the Bub and Rinehart mufflers. The three sets I have over the years all rattled over time.
Steel Steed
May 5, 2012 04:39 PM
FunkyNova66
Exhaust System Topics
Aug 25, 2009 09:41 PM
vettedog72
Feb 24, 2009 09:47 PM
Nickpisp
Feb 6, 2009 03:25 PM
radridd
Aug 12, 2007 08:46 AM
