Cleaning black engine
Old Aug 7, 2010 | 12:10 AM
AK BAGGER's Avatar
AK BAGGER
+1 on the 50/50 Simple Green and Water. Spray it on a cold motor and then hose it off before it drys.
Be careful with the S100. Although it does and excellent job of cleaning, it's very caustic and will corrode the aluminum on the engine cylinders if it's not rinsed completely. Even with my maticulous cleaning habits, I still find corrosive spots on my machined aluminum areas of the engine. I quit using the S100. The simple green gets the same results without the corrosive spots.
Old Aug 7, 2010 | 12:20 AM
Grizzx2's Avatar
Grizzx2
Thumbs up
"Pig Spit" is that better than Calf Slobber?
I just had to say it.......
Old Aug 7, 2010 | 12:25 AM
dohadex's Avatar
dohadex
Wink No Touch Tire care....
Wash the bike as normal...let dry, then only on the black parts, spray No-touch Tire care. It will brighten up that blackness like like show-room new.
Old Aug 7, 2010 | 12:29 AM
DZLDR's Avatar
DZLDR
Although pig spit and s-100 are good for dressing up the black finish on the engines, I believe the OP was wanting tho know how to get the crud off his engine.
I use those big *** baby bottle brushes (they come in several sizes)I get at the dealership. They are very flexible and Great for getting in all those nooks and crannies.
Old Aug 7, 2010 | 02:07 AM
mike5511's Avatar
mike5511
pressure wash, doesn't hurt a thing and it works real good.
Old Aug 7, 2010 | 02:30 AM
kingcobra's Avatar
kingcobra
Originally Posted by Gusltd
Just keep her clean. I wash my bike after every ride with nothing but soap and water. I never use the latest and greatest chemical. I had a roadking for almost 10 years and the bike looked like it just rolled off the showroom floor. Nothing but soap and water and also be sure to dry her off as to not let the water spots build up.
Ditto. Soap and Water
Old Aug 7, 2010 | 06:58 AM
jrspada4's Avatar
jrspada4
+1 on the 50/50 Simple Green and water. I put it in one of those sprayers from the garden center that you pump to pressurize and then use a spoke brush to work on the tough bits. The HD ones are soft enough to not scratch surrounding chrome and the wire frame is coated to help prevent scratching.
Old Aug 7, 2010 | 07:05 AM
NewAge's Avatar
NewAge
Ah thanks, yeah that was more what I was lookin for. Although now I'm definately going to try some pig spit. I have never heard of it so hopefully that's really what its called so I don't look like a fool askin for it somewhere. Thanks all for the replies!
Old Aug 7, 2010 | 07:16 AM
Iceman24's Avatar
Iceman24
Ditto and I found a way to use the old toothbrushes vs. disposing. Gr8 for getting into the small areas & don't hurt finish. So...let the scoot cool, hose off, spray down w/selected cleaner (S100, Pig spit/snot, green, etc.), & brush away. Also, 50/50 mix of peroxide & water works sell on bugs. Good luck & clean 'er up like you would do w/the weapon(s) - Marine!...;-)
broziff's Avatar
broziff
Dude your avatar is mesmorizing its hard to look away.
