Back to Conventional
Old Aug 16, 2010 | 07:04 PM
  #41
sargek's Avatar
sargek
Correct me if I am wrong, but noise in an engine, as in clattering/ticking, etc, comes from metal hitting metal. I understand engines make noise, but when clattering and ticking gets louder, to me that signals something bad. I could be wrong, but I'd rather not find out the hard way.
Old Aug 16, 2010 | 07:23 PM
  #42
voodoodrug's Avatar
voodoodrug
my mercedes benz manuel calls for mobile 1 0-50 synthetic oil and says to change it every 10 to 16 k wow so im wondering if when i change it ,which is every fall around september sence ive only driven it 6k can I run it in my bike till for another year? and add some of that motorkote stuff aswell? vs dyno oil
Old Aug 16, 2010 | 08:25 PM
  #43
myred55's Avatar
myred55
Is there anything special you need to do when changing from syn. to dino? Flush the motor or just drain the syn and put the dino in?
Old Aug 16, 2010 | 08:32 PM
  #44
Mike's Avatar
Mike
Take the old oil out, put the new oil in.
Old Aug 16, 2010 | 08:56 PM
  #45
UPSGUY's Avatar
UPSGUY
I want to go back to Dino oil but I have been told that once you go synthetic you cant go back??? Im running Amsoil 20/50 in all three??
Old Aug 16, 2010 | 09:04 PM
  #46
myred55's Avatar
myred55
I was told the same thing that's why I questioned it.
Old Aug 16, 2010 | 09:38 PM
  #47
RAP's Avatar
RAP
Thumbs up
Well, this red beast runs great with the following: M-1(3 quarts) Lucas Stabilizer(1/2 quart) and K&P Oil Filter. Good oil pressure, Good oil flow, minimal noise in the top in and she does not use a drop of oil between changes!
Old Aug 16, 2010 | 09:55 PM
  #48
xxxflhrci's Avatar
xxxflhrci
On the other side of the coin, my decade old Twin Cam still runs great using nothing but dino oil and a black HD oil filter, has 80k miles on it and doesn't need a drop added between changes either.
Old Aug 16, 2010 | 11:04 PM
  #49
Harleyboyddk's Avatar
Harleyboyddk
Run Mobil V-twin synthetic in both bikes. I put roller rockers with needle bearings on the rocker arm shafts in the White Lightning and it's as quiet as a sewing machine. And this motor runs hot in the desert here. Same oil in the twin cam and noisy top end. Had room in crankcase for 1/2 Qt. Lucas synthetic oil stabilizer and noticable reduction in mechanical noise. Lucas recommeds 25% Lucas Oil stabilizer In HD motors, so next oil change will use full quart in motor.
Old Aug 16, 2010 | 11:22 PM
  #50
Mike's Avatar
Mike
And did they tell you why? It's not true, btw.
It's not like swapping back between DOT4 and DOT5 brake fluid.
cowpoke
Oil Archive (no new posts)
May 24, 2012 01:37 AM
2007rkjb
Jan 21, 2011 01:32 PM
lhcstreetbob
May 7, 2009 10:56 PM
BlackFLHR
Dec 20, 2008 09:12 AM
damnitj
Oct 11, 2007 07:20 PM
