transmission
Old Aug 9, 2010 | 08:16 AM
aposto's Avatar
aposto
Default transmission
the rear shifter linkage is loose and will not tighten up , went to harley and bought lever and bolt they say to replace this you must split cover. is there a easy fix 2006 ultra
Old Aug 9, 2010 | 08:22 AM
dog155's Avatar
dog155
They are right, inner primary needs to come off.
Old Aug 9, 2010 | 08:35 AM
tenn.vol.'s Avatar
tenn.vol.
I have seen on this forum a tranny shifter linkage that is 2 piece. (That is how it
is securred to the tranny shaft) So if you could cut the old shifter off with a Dremel
tool???? Someone need to look into this before I need to replace my shifter linkage.
Tenn.Vol.
Old Aug 9, 2010 | 08:38 AM
Scorpion07's Avatar
Scorpion07
Most likely not. The splines on the arm probably opened up once it came loose.
There's no way to get the arm off, even if there were a 2-piece replacement, without removing the inner primary.
Old Oct 4, 2010 | 09:06 PM
heavymetalthunder7's Avatar
heavymetalthunder7
Stage I
call me 757-715-0254, or go to betterlever.com , I'm near you, I am Conrad Buehler, hope I can help if you r still having problems, thanks
Old Oct 4, 2010 | 09:28 PM
head's Avatar
head
i had a buddy that put a regular bolt in his instead of the allen head. was able to torque it down a little more. worked fine without having to replace it.
mine got loose on a previous bike. i was real busy and didnt have time for it to be down but didnt want it to come off either. got a universal throttle spring for a car and hooked it somewhere(dont recall) to keep the pressure on it. rode it like that for a couple of years until i needed to replace the belt and was there anyway. worked great and didnt looked rigged up either.
head
Old Oct 4, 2010 | 09:47 PM
Duke02's Avatar
Duke02
If it makes you feel better, not only is my shift shaft loose but the seal is shot too!
No other fix but to remove primary....
I like the spring idea and the idea of a new two piece, but I'd like to see someone shove a dremel tool between the tranny and the primary case!
tsigwing
Apr 5, 2019 07:14 AM
LMCI-Enforcer
Dec 29, 2018 04:19 PM
PFR-Captain
Nov 13, 2014 07:46 PM
DanDman
Sep 16, 2008 10:53 AM
zubaugh
Apr 26, 2008 01:25 PM
