01 RK Tranny leak.
Old Aug 19, 2010 | 01:21 PM
King SS's Avatar
King SS
Default 01 RK Tranny leak.
I have a leak on the right side on the tranny somewhere. It leaks parked overnight in the garage, a lot! I'm headed out to look at it now, but if you have any ideas throw them my way please. Thanks
Old Aug 19, 2010 | 01:39 PM
carpetride's Avatar
carpetride
put a pan under it
Old Aug 19, 2010 | 02:06 PM
xxxflhrci's Avatar
xxxflhrci
I had a minor leak about 5 years ago on my 2000. I found a couple of the end bolts needed snugged up. That took care of the problem.
Old Aug 19, 2010 | 02:42 PM
King SS's Avatar
King SS
Found 3 bolts loose behind the clutch cable cover!
tj316's Avatar
tj316
alot of times it's not the tranny, it's back side of inner primary, shifter seal or 2 bolts that have seal on them or it could be the seal on tranny at sprocket, you will probably have to remove inner primary to fix
Old Aug 19, 2010 | 02:57 PM
Sgt. Fury's Avatar
Sgt. Fury
Usually the leaks on the right side are the bolts that hold the exhaust bracket on.
Old Aug 19, 2010 | 05:09 PM
xxxflhrci's Avatar
xxxflhrci
Put a little green Loctite on those bolts and the rest on the tranny end and you should be good to go.
Old Aug 19, 2010 | 05:51 PM
Firetender's Avatar
Firetender
+1 on the exhaust bracket, I had a bolt fall out and the resulting leak cost $2 to fix for the new bolt.
Old Aug 20, 2010 | 12:25 AM
King SS's Avatar
King SS
Thanks for the info on the green loctite!
Old Aug 20, 2010 | 04:24 AM
BadPiggy's Avatar
BadPiggy
Nobody mentioned the clutch cable o-ring.
