RK has idling problems
Old Aug 20, 2010 | 06:59 PM
Freeriderick's Avatar
Freeriderick
Stage IV
Default RK has idling problems
OK, first off, i'm a newbie. Mechanically inclined, suck at diagnosing problems. Here's what's going on....
2005 Road King FLHRI - 95" kit, Cam, exhaust, Power comm.III
1. took bike for ride. got home. washed bike. .went to start-no start..
2. Finally got bike to start....idles irratically..pops and idles high..
3. got trouble codes from bike. po373 & po374. Crankcase position sensor.
4. bought CKP and replaced...-- Problem still there. also noticed that when Run/Stop switch is OFF, there is something on the intake manifold that is RUNNING, with everything turned off. i turn the switch to RUN---it goes away..?
Bike idles at about 2000- 2500 rpms.
Any ideas..? i'm thinking throttle position sensor...Hope someone has some insight so i don't have to replace evrything on the bike...
Old Aug 4, 2011 | 04:30 PM
drspencer's Avatar
drspencer
I'm having a similar problem. Did you ever find the fix?
Thanks
Old Aug 4, 2011 | 04:32 PM
killerk95's Avatar
killerk95
Check battery connections for tightness. Loose cables can affect computer etcc...
Old Aug 4, 2011 | 05:23 PM
mrfikser's Avatar
mrfikser
give the run/stop switch a good looking at ..with a meter....although it is 'prolly a water issue and will go away on its own..
Old Aug 4, 2011 | 05:35 PM
Freeriderick
Stage IV
My problem turned out to be that I was getting water into my control module connector, where my power Commander cable hooks up. I blow dryed the connector, wrapped with electrical tape. Haven't had the problem since.
Old Aug 4, 2011 | 08:13 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
use some dielectric grease on the connector and that shouldnt be a problem.
Kettenhund75
Feb 17, 2021 02:38 PM
seumasticon
Electrical/Lighting/Alarm
Apr 16, 2015 03:31 PM
NightStalker06
Apr 27, 2013 06:47 PM
randy switzer
Oct 19, 2011 09:49 AM
ezgary
General Topics/Tech Tips
Apr 29, 2009 08:35 AM
