Help with a problem
Tonight after class it would not start. I called the local HD Dealer and they told me to take off the side cover and check the connections. I took each connection off, check it for "crud" and they were all dry and as clean as could be.
I let it sit for another 5 minutes and it started. Then it died again. I tried to start it again and it started. I rode it approx. 45 miles home and when I pulled in the garage it idled just as smooth as it ever has.
I am not sure if I have a electrical or fuel problem. I could not smell any gas no matter how much I turned the throttle to see if that would help start the bike.
Any idea where I should start my trouble shooting?
Thanks in advance for your time and assistance.
NS
Last edited by NightStalker06; Apr 25, 2013 at 10:34 PM. Reason: added more information on my problem
On early twin cams the bracket holding this sensor could break due to vibrations, leaving the sensor swinging on it's wires- it is kinda like a "tilt" switch on a pinball machine.
to check this, with motor running, lean the bike from side to side ( get help)...shake the darn thing...if it cuts out, then you know.
in this case it will not even crank - when you say it did not start- did the motor turn over or just...dead ?
another check is the ignition switch, the switches were not the strongest and the lighting power runs thru the same contacts and can arc and pit
mike
Mike: The bike would crank, but not start. Then I would crank it again and it would start..... then die.
I "googled" tip-over sensor / switch and these were the results: https://www.google.com/search?q=harl...w=1366&bih=667
Could you narrow my search by selecting the one which most closely resembles what you'd expect to find on my bike?
I will run out t the garage, drop my bag and cover in order to get a pic and post it.
Thanks again.
NS
Tomorrow I'll remove the console and see it there's anything unusual going on under there.
Thanks again for the assistance.
NS
Ok... I've tried to run down most of the recommendations from the HD Forum Team and I think I have narrowed it down to a fuel problem.
I removed the air clearner, and if I prime the carb (actually EFI) it will start and seems to run fine. I warmed it up, them took it up to abot 2500rpm, back down, back up, and then let it idle.
After idling for approximately 5 minutes is starts to lower the idle RPM and then stops.
It will not start again unless I prime it. I am running good gas through the system, but it did sit for a considerable amount of time before I bouht it last fall.
Any ideas based on this update? I hate to carry a squirt bottle of gas with me on my ride tomorrow!
I've traced the fuel lines as best as possible, but I do not see a fuel filter. I see a cross-over fuel line between the tanks and a fule line running into the EFI, but I cannot seem to locate the fuel filter. Can anyone point me in the right direction?
Thanks again for all the help fellas. I truly appreciate it.
NS
