Spark Plug Change @ 5k
Old Aug 24, 2010 | 06:40 PM
bwana1's Avatar
bwana1
what he said...and then replace them with Champion RA8HC, $1.39 a piece.
btw, does anyone really think that HD makes HD plugs? Compare them with that Champion RA8HC and I think you will know who makes the HD plugs,
Bwana
Old Aug 24, 2010 | 06:53 PM
CrusingHarley's Avatar
CrusingHarley
Originally Posted by oley55
crazy talk. these plugs are operated in an ECM/EFI system. reality check, they are good until they ain't. no way they will get fouled or otherwise with EFI. frankly, snatching on the plug wires and removing the plugs to check the gap will do way more damage than anything.
leave the damn things alone until something (mileage/performance drops) tells you they need to be replaced.
+1......
Old Aug 24, 2010 | 06:58 PM
HOG_0308's Avatar
HOG_0308
i do all my own work on my scooter. every 5k miles, all three holes, plugs and oil filter.
Old Aug 24, 2010 | 07:11 PM
xxxflhrci's Avatar
xxxflhrci
I don't see the point of changing plugs at 5k miles....Both a waste of money and good plugs. Run 'em till your performance and/or gas mileage suffers...IMO, the less you got screwing the plugs in and out the better.
Old Aug 24, 2010 | 07:13 PM
Notgrownup's Avatar
Notgrownup
Mine have 45000 miles on them...screaming eagle triple platinum....take them out and check them and put them back in ...look fine so i don't see the reason to change them...i might this year??? for the hell of it...
Old Aug 24, 2010 | 07:48 PM
BurgundyUltra06's Avatar
BurgundyUltra06
Originally Posted by CrusingHarley
+1......
Gotta agree with Crusing, Bwana, and Oley on this. You gotta know when your plugs aren't firing right, and it's an easy fix (clean/re-gap or replace). If it ain't broke, don't fix it, just have a spare with ya. That said, preventative maintenance (clean/gap) won't hurt ya in the interim.
Old Aug 24, 2010 | 07:50 PM
twodollarbill's Avatar
twodollarbill
I change them at 10K
Old Aug 24, 2010 | 08:19 PM
t. sawyer's Avatar
t. sawyer
Thumbs up
+1......
+2
kroozeabout.
Old Aug 24, 2010 | 08:25 PM
Ouroboros's Avatar
Ouroboros
Replacing plugs at 5K miles? I was unaware that HD made a two stroke.
Old Aug 24, 2010 | 08:34 PM
BurgundyUltra06
Now that's funny there...
