Need help NOW!!!
Old Aug 27, 2010 | 10:01 AM
FastHoss's Avatar
FastHoss
I talked to some bike cops about 5 years ago in Las Vegas about the heat.They told me they had never lost a engine to heat and the dept.does not pay for synthetic oil and no oil coolers.These bikes were designed for the heat.At least the older models.Harleys are not as fragile as most newbie owners believe.
Old Aug 27, 2010 | 10:11 AM
nutsandbolts5212's Avatar
nutsandbolts5212
That's good to know.
Old Aug 27, 2010 | 10:20 AM
petemac's Avatar
petemac
Then why say, "Need help NOW!!!!". Sure makes it sound like the guy is stuck and needs help NOW to get the bike going.
Originally Posted by skratch
contrary to popular belief, not all people are able to sit on the forums and wait for an answer to their post. sometimes i'll post and won't be able to check the forums until the next day at the earliest......
Old Aug 28, 2010 | 08:07 AM
Jambon1's Avatar
Jambon1
That is exactly the case!! I was stuck in a bad situation and was trying to get to an important event. I did not have time to REPLY even though I read all the posts by other members. Again, thanks to those who tried to help. And to those of you who are more interested in increasing your number of posts and turn this into a bitch session FO!
Old Aug 28, 2010 | 08:36 AM
Jambon1's Avatar
Jambon1
Originally Posted by frenchbiker
"Jambon" as "ham" in French? You're French or French Canadian?
As in the name of my first Harley a 1979 FLH purchased in Paris while I was stationed in the UK in 1985.
It sounds better in French.....Sszzhhambon!
Old Aug 28, 2010 | 08:50 AM
psychocircus's Avatar
psychocircus
Originally Posted by JCleary
I ride quite frequently with two other guys on '09 baggers. One has a 103" (no oil cooler) and the other is a stock 96" with Woods 6-6 cams like my bike.
Sitting at a light, the 96" always seems to go to one cylinder, while the other two bikes take far longer to get there. All three bikes were tuned by the same guy.
I suspect the cylinder head temp sensor has some variance from the sensors on our bikes causing the bike to think it's too hot. I suspect the same is possible with an oil pressure gauge.
Given the info that the OP had, I would also have changed out the oil. Watery oil is no bueno. Cheap insurance.
I run Redline in my bike, summer or winter. Never had any issues, but I haven't seen Arizona or Nevada heat either...
mine is totally stock and if the oil level isnt juussst right it will kick down to 1 cylinder faster at stops...but other times i wont ever get it to drop down...im in nc with temps round 90 and with heat index 108!
Old Aug 28, 2010 | 09:15 AM
petemac's Avatar
petemac
Take a f** prozac dude, it was just a observation. I hope I didn't make you cry. Get a grip.
Old Aug 28, 2010 | 09:24 AM
VETERAN75's Avatar
VETERAN75
The 96's do run hotter. Bigger engine, more heat. Your rear cyl probably did shut down. At that point you should be looking for a highway to get some wind or pull off and shut down a few minutes. Your oil at point is over 300 deg. Normal runnning temp is around 230. I was told the afr's at idle make it run hotter also. If your going to be in that situation alot you may want to see a tuner about tuning your bike to run a little cooler. Ride safe.
elchoche23
Oil Archive (no new posts)
Jun 16, 2018 10:11 PM
sluginxlt
EVO
Sep 25, 2016 10:21 PM
WideGlideFever
Dec 16, 2013 09:10 AM
viarengo
Feb 26, 2013 09:25 PM
alyaseen
Aug 15, 2010 08:40 AM
