Need help NOW!!!
Old Aug 26, 2010 | 05:42 PM
Jambon1's Avatar
Jambon1
Default Need help NOW!!!
Sitting in traffic for over 40 minutes engine got REAL HOT then oil pressure dropped to almost zero. Engine oil light is now on. Checked oil and level is good. What's going on??
Old Aug 26, 2010 | 06:09 PM
valvestem's Avatar
valvestem
Any associated engine noise? You didn't say.
Old Aug 26, 2010 | 06:11 PM
user 8373900's Avatar
user 8373900
Probably throwing a code. Clear it and see if it goes away.
Mark
Old Aug 26, 2010 | 06:24 PM
bagman1's Avatar
bagman1
Im sure your oil got too hot and thinned out causing the light to come on. I would change the oil and that should take care of it, if not you at least have to start with this step. This happened to me last year on a trip where I lost 20 psi, the oil was full but looked like water and was dark. After I changed the oil it was fine, also if you were overfilled or right at the top of the full mark the oil will thin out from aeration of having too much oil in the bike. Most will say to leave it about 1/2 qt below the full mark, especially in high heat locations. You have lost most all of the lubricity property of that oil from the heat and I would dump it and put in new oil/filter.
Old Aug 26, 2010 | 06:26 PM
bwana1's Avatar
bwana1
oil thinned out??????????????????????
wtf
Old Aug 26, 2010 | 06:36 PM
bagman1's Avatar
bagman1
wtf
Your from Az and you never seen oil thin out???
Old Aug 26, 2010 | 06:42 PM
Ronp42's Avatar
Ronp42
Account Retired
What Brand of oil and the weight??
Old Aug 26, 2010 | 07:47 PM
themensh's Avatar
themensh
Don't your bike have 'parade mode' or something? Why you sitting for 40 minutes? Shut the motor off at least, doesn't take that long for the engine/oil to cool down 40 degrees.
Change your oil, and go for a ride....tell us how it goes.
Old Aug 26, 2010 | 07:50 PM
Harleyboyddk's Avatar
Harleyboyddk
I take my cue from the local bike officers. In the heat, shut the bike off until lights change or stopped traffic begins to move again. I've seen this alot in Las Vegas.
Old Aug 26, 2010 | 08:11 PM
Ultra61's Avatar
Ultra61
Why would you post that you need help now?...and not once respond to these questions from people who are just trying to help. 2 1/2 hours have passed
