Anyone know the correct torque values for caliper bolts?
Old Sep 4, 2010 | 11:44 PM
cruzmisl's Avatar
cruzmisl
Default Anyone know the correct torque values for caliper bolts?
Hi All,
I picked up some polished stainless bolts for my calipers from Diamond Engineering. Not the mounting bolts but the two bolts that keep the caliper halves together. I looked in the service manual but couldn't find the correct torque values for those. Anyone have any ideas?
Thanks,
J.
Old Sep 4, 2010 | 11:54 PM
Harleypingman's Avatar
Harleypingman
I doubt you can find them from HD because the Brembo calipers are not rebuildable according to HD. Absent someone else chiming in with some reliable information, check with those who sell OEM calipers that have been chrome plated--they ought to know how to put them back together.
Carl
Old Sep 4, 2010 | 11:57 PM
Springerfan's Avatar
Springerfan
Torque them to 10.7 ft-lbs with anti-sieze or loc-tite on the threads.
Old Sep 4, 2010 | 11:59 PM
BadPiggy's Avatar
BadPiggy
Pingman is correct.
There is no rebuild kit available for Brembo's, nor is there any info in the Service Manual.
I installed the Diamond Engineering Caliper Kit on my '09 RG.
I torqued the bolts that you question the same as the old calipers.
I can't help you with that.
My manuals are at my shop.
Old Sep 5, 2010 | 09:32 AM
Springerfan
I was in the same situation when I replaced the caliper bolts on my chrome calipers. The ones from HD that came with the chrome calipers didn't look to good. The torque value of 10.7 ft-lbs is what I received from the manufacturer of the G8 polished stainless bolts that I used. I also double checked with a service mechanic at my dealer. The bolts came from Alloyboltz.com
Old Sep 5, 2010 | 09:35 AM
Notgrownup's Avatar
Notgrownup
WHatever a Craftsmen wrench can handle from a framing hammer...LOL...
Old Sep 5, 2010 | 09:44 AM
cruzmisl's Avatar
cruzmisl
OK sounds good. Thanks for the replies. I have to say though 10ft/lbs sounds low but is probably right. On the flipside I think the framing hammer torque is too high
Old Sep 5, 2010 | 10:20 AM
Springerfan
I thought the 10.7 ft lbs was low at first but I believe that the calipers are alloy so too much torque could be costly. I have had no issues since I put them on 6 months ago.
Old Sep 5, 2010 | 11:31 AM
Notgrownup's Avatar
Notgrownup
Yeah....maybe i went a bit to tight with the hammer....
Old Sep 12, 2010 | 01:42 PM
cruzmisl's Avatar
cruzmisl
I installed the bolts today but there was no antiseize or loctite on the ones I took out. I didn't put either on when I installed them but wondering if I should have.
