Reinstall stock headers, slip ons
I already purchased 2 new gaskets and 2 new exhaust clamps, but looking at the service manual, I need 4 clamps all together. It also looks like I will need a swivel socket to get to the bottom nut of the rear exhaust flange.
Are there any other "gotcha's" I should look out for? I do have the service manual and will be removing and installing the exhaust as specified. I will also use all new gaskets and clamps, just want to be sure I'm not missing anything. Oh yeah, i will be taking my time and have plenty of time allocated for this.
Thanks in advance!
If all else fails...
Make sure you use stock exhaust port gaskets because they usually seal the first time. One side of these are concave. The SE gaskets are thin and flat on both sides - I don't recommend these.
If you are chasing a leak then buy some Permatex copper gasket sealant at the auto parts store. During assembly, use the gasket sealant where the exhaust joints join with each other and to the mufflers as well. Obviously do not use the gasket sealant where the header pipes join with the engine. Wait a day before you fire the bike up so the gasket sealant can cure.
When you get the swivel socket make sure it is not one of those universal types that you put a half inch socket on. Get the actual swivel socket with the half inch fitting. There is more room this way. I like to add some anti-seize on the exhaust port studs and using new bolts does not hurt either. Stripping the exhaust port studs will completely ruin your day so take care not to over torque or bang the exhaust heads on them too badly.
Hope this helps. Take your time. I don't have to tell you that removing and installing the exhaust can be a major PITA.
If you think you have an exhaust leak, you will be well advised to make up a mandrel from some 2" O.D. steel tubing about 10" long, and bevel one end's outer edge to about 45ş (on a grinder or belt sander) so you can slip/drive it into larger joints (that slip over the other pipes) in your exhaust system, and use it and a ball peen hammer to re-shape that area that is deformed by the torca clamps. Use some silicon hi-temp sealer on the joints, as well as the new torca clamps (they can stretch after use and not seal properly if re-used).
Also ....... a hint as to what way to adjust the map can be ascertained by the sound of the decel popping.
'Typically' ..... if it's a loud, sharp, snapping pop then you are probably too lean, if it's a muffled pop then you are probably going to be correct to assume it's rich, at the 0% throttle position.
Adding a count in that map area of +/- 20 (or even much more) might help you dial out the popping.
On edit ...... almost forgot ....... Yeah, some of the gaskets are tapered and some are not.
I'm not sure what's up with that, but it seems to be a difference between newer post '84 OEM gaskets are tapered, and pre '84 'and' some newer aftermarket gaskets are not.
I assume it's a preference thing these days, but hopefully somebody with more knowledge might post .... (???)
I have the SERT but don't know how to add to the map, the dealer did it for me. Guess I will have to make an appointment for them to do it. The popping I'm getting sounds like muffled, lower volume pops. They are not loud or typical sounding backfires
It might be worth studying up on the SERT to learn how to change settings. That way you can experiment with optimal settings later on. All you need to do is change the zero percent throttle settings up or down in 5% increments. I use the PCV. Hooking up the laptop and changing the settings only takes a minute or two.
